pioneer DEh-p6700mp wiring help!!!!
i hve a used pioneer cd player i have ll the wirers matched but 2, a orange w/white strip and a yellow w/black strip which one of these do i hook up to the blue wire??
thats wired cause i dont have an antenna..... the way the stero shop had it connected was that blue wire going to a blue w/white wire with the amp wire on that all together on my old deh-p4000.
it will also connect to that.. It gives a power on signal to the amp to turn it on so it won't drain your battery while the acc. is off.. On the amp it's hooked up to the remote. On an amp.. there are three plugs. 12v, remote, and ground
correct if u have any electrical questions ask me thats where i might be able to help you
^ ........................................^hmm i dono might be memory
that for your lights when u turn dim so the cdplayer dims out in
well i just hooked it up to the yellow w/white sripe and it seemed to work so i took it and tucked all the wires connected it back and turned it on now it says, "MUTE" and no sound will come play....... how do i get that off?
undo the that wire, it's to mute the radio for your handsfree kit when you are getting a incoming call. do you have a blue or blue w/ white wire. hook it up to either one of those for your amp turn on wire.
