- Getting my ECU programmed
- Can you guys help me out please!
- D16Y8 Tips
- Spark Plug Model Number
- young DX owner need Help please.
- 99-00 Civic Si Sway Bar upgrade Ques???
- Muffler Silencer question??
- Torque on the headbolts of a d-series
- Over or under damped suspension - or mismatch sucks!
- suspension
- swap
- Rebuild Junkyard engine?
- 98 DX High Beam Installation
- Honda Civic CEL misfire cylinder 3
- Need help finding a wheel
- alternator adjusting bolt
- Opinions on 4.785 final drive install. Should I?
- Stiff Throttle=good, but for how long..
- upgrades
- Help Please
- SHITake MUFFLER
- Check Engine Light
- Car won't start.
- removing the cat
- Looking for ITB's for a 99 b16a can anyone help ?
- Exhaust question...
- b16 axles...
- Cold Air Intake!
- Keyless Solenoid??
- Tie bar and sway bar
- need a honda civic si 2004 body parts
- Tie and Sway bar
- Do all 97 LX civics have keyless
- What do ya think???
- Ive search, but obviously not hard enough
- 7th gen tweeters
- Tranny decision for allmotor b20(possible vtec head conversion later)
- Void Warranty?
- Which High Beams?
- B16a Headers
- K, I've been searching suspension set ups.
- h22 swap intro 95 civic coupe
- O2 sensor problems!!!
- REVENGE singlecam with more then 200lbs of torque
- 02 Honda Civic
- wierd noise from 3k up
- Tint Laws in Tennessee!! ****HELP***
- eg questions
- engine oil leak after tranny swap
- How do I install a Momo Steering wheel
- Drivers Side Door Wont Lock With Alarm Turned On
- Need help with horn PLEASE!!!!
- Putting in a factory HU to get keyless in a 97 civic
- '00 factory security system
- 01 Civic seat issues
- '98 Civic New Clutch "Problems"
- What can i get?!
- whats the difference?
- How do you know when a relay has gone bad?
- How much would you pay?
- 01 Civic coupe mirror replacement
- Question about sidemarker wiring???
- clunky-clunk
- SS or Ceramic headers?
- Charging?
- maxboost?
- rice?
- D16block/b18 Ls Pistons
- Tuning a Apex'i VAFC
- 03 civic bumper removal
- port and polish
- Question on motor
- 94 Honda Civic 4dr Black LX for $700?
- part identification
- alternators --interchangeable????
- ls torque specifications
- Anyone wanna help a Dumba$$???
- SOHC vtec head/cam question
- The Venom 400
- top si radiator hose doesnt fit b16.
- Question about city lights???
- `05 Civic Special Edition Stereo (hard to find, I'm sure)...
- turbo with/with out cat
- How to replace Side Mirrors
- Bad Throttle responce, boggs a lot?
- transmission question
- B16 hydro tranny?
- Radiator?
- Good deal?
- My System is maken my car act weird
- Strut Bar
- 92+ rear brake drum 2 disk. How to???
- 93vx b18c1 swap
- Question about JHPUSA.com???
- How do I use my alarm?
- Wierd noise coming from alernator??? help
- 99 Honda Civic LX!!!! **Help!!!!question???
- I need help!
- EK Mugen knock off wing....
- New OBD1 chipped ECU question
- Fuel stability ??
- cluster problem. help
- Quick Question
- 92-95 Honda Civic Hatch Shell
- Wiring diagram needed for 1994 honda civic dx 4 door
- How much transmission oil fits in Acura 1.6 EL?
- Type R Suspencion?
- Headlights/Tail lights
- sway bar question..
- Getting an abused 92lx back to good
- Is it a problem or just the worst pos ever?
- stupid stupid people
- some kind of grind when i let clutch go
- Yet another question about mirrors??
- Does she have ABS?
- Altezza Lights!!!!???? ****Help***
- used motor price
- Get Rid Of Your Crap Air Filter.
- motor mounts...
- reply
- What do y'all think this will cost to fix
- 96-98 honda civic dx angel eye projectors
- Need Help With Skunk 2 Cam Gear!!!! Anyone Know About This?!?!
- Overheating
- 96-98 OEM front lip
- Need your opinion -- clutch replacement
- 2000 Civic DX intake
- sourcing parts for the Acura EL
- Squeeking noise from front end
- b16
- Brake Upgrade?
- Fog light wiring help??
- How much is my car worth? Just wrecked!
- 90-93 integra rs motor in delsol
- help with wiring LED s to a toggle switch
- Nice gauge cluster.
- Have you checked your rear trailing arm bushing lately?
- B18C5 Boostage?
- is it true...when you put in a short shifter?
- research...
- OEM honda parts?
- Shutters then grabs!
- looking for 04 civic si cluster wire dirgram
- OBD-1 in an OBD-2 Civic?
- quick question--liquid gasket :oh:
- how do you take it out?
- Acura 1.6EL is how much of a civic?
- '92 civic coupe speakers & wtb?!
- wiring amber LEDs inside gauge cluster
- my +1 tires are sticking outta the fender
- Is this possible, trying to be least painful as possible
- Noisy Idle AC Compressor?
- D16Y7 head on D15 block?
- 6th gen sideskirts on a eg
- install help EG rear ST sway bar
- humming even after $300 at the mecanic
- Front bumpers...
- Just got my 03 Civic LX...
- Availble Engine Swaps
- This a deal?
- Korbach Frame Locks review–New EG Civic Beta Tester # 3
- Any trick to driver side axle?
- B16A 1/4 mile times??? what have you seen?
- Help!!!! Is my hood ugly
- starter question
- my low boost dseries dyno!
- EGR valve???Bogging.
- Turbo Kit is complete.... Now final step
- Color code for 00' Si Electron Blue
- Lucky 13 Strikes Again, Car Wont Move
- What engine fits a 98 civic LX
- honda distributors
- Need Help!!! Pressure Plate Bolts
- bedding new brakes/rotors
- See The New Honda Civic Si Concept At Sema Ias On May 22-25 At Atlantic City, Nj!
- Engine harness ?
- JDM SHIT Q's
- What does the Honda dealership say about your aftermarket parts?
- 1998 Civic problems- Help!!!!!
- Ran into 3 problems, simple solutions?
- caliper question
- swap??
- how do u make a custom intake?
- headlight bulb?
- dx cluster to Ex or si cluster
- aem v2 intake
- lookie what just game in the mail!!
- Coolant problems....need ideas!!!! Long....
- treating your babies right!?
- New exhaust..Is it true it will get louder?
- BAD noise HELP!!!!
- Some 2004 videos of my 00 Civic Si.
- what does boosting most effect?
- Squeaky power window
- Muahaha..ha...eh...
- check power to fusebox
- Grinding Sounds in Reverse?
- Ok, I used my old harness on the b16..now what.
- HELP!!! Rear bearing drum brakes 1992 CivicLX
- Home made urethane bushings - urgent
- high compression
- header question
- looking for some nice rims for del sols.
- B16a2
- Yet another Civic headlight question???
- What oil?
- air razor??
- wat size head gasket to use on d16y8 turbo?
- Mileage Problems
- Del Sol sidemarker wiring???
- getting clutch soon
- Service Manual
- Speaker removal
- Found new oil leak
- B16 swap..
- speedometer problem...
- Civic Engine Types
- engine swap
- 99 Civic Si Exhaust
- I still cant figure it out
- '97 Civic EX hard starting
- $7000 to play with...
- interior vinyl
- Ordered 17's got 18's
- Cat Back Exhaust
- 99/00 Steering wheel install with real srs disable
- Best brand of headgasket for Civic
- Ok, well my b16 harness is intact, should I use my current one anyway?
- painting stock skirts and lips
- YAY! I got the engine out!
- Noise from left front wheel
- power mirrors...
- Tein coilover systems
- quick explanation...
- Some new pics
- Car wont start...help!
- Best turbo for a B20b with b16 trans?
- valve cover paint?
- need a new look
- Radiator fan still isn't coming on...
- What do you think about these headlights?
- ECU help
- Will these wheels fit my car?
- Faded Plastic Door Moulding Trim
- Messed up paint...
- Some kind of grease all over the inside of the wheel.
- Need MUGEN RNR center caps (15'')
- Noob wants your opinion
- 00 civic interior
- need a quik favor from b18c owner
