fuel pump question
Old May 9, 2005 | 07:08 PM
2000Si's Avatar
2000Si
Default fuel pump question
im peicing a turbo kit together that is going in when i get out of school this summer. isa new fuel pump needed before i drive it with the turbo on my car or am i safe for a month or two until i can get one? let me know, thanks.
Old May 9, 2005 | 07:18 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I don't have fuel pump...yet. How much boost do you plan on running, what size of injectors are you planning on running, and how are you getting it tuned?
Old May 9, 2005 | 07:21 PM
2000Si's Avatar
2000Si
so i can get the turbo broken in right and everything im gonna run low boost for a little bit. im thinking around 6lbs. one of my good friends is a manager at a place called high point industries and hes gonna help me. he put a turbo in his car.
Old May 10, 2005 | 02:48 AM
Outxider's Avatar
Outxider
X-Motoring
u will be fine for the moment. when u start goin crazy with a built motor and more psi, i suggest lookin into walbro pump.
Old May 10, 2005 | 06:29 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:werd:
But you need to decied on the 255 LP or 255 HP. If you plan to boost something like 18+ psi, I recommend the HP.
