Tyre Pressures
Old May 12, 2005 | 08:03 AM
g32turbo's Avatar
g32turbo
Default Tyre Pressures
Hi,
I'm new to Honda-Acura.net so apologise if this question has been answered before.
I have replaced my 14" wheels (with 185x60x14 tyres) with 17" wheels and 205x40x17 tyres. What tyre pressures should I be running for normal road driving?
Cheers, Tony
Old May 12, 2005 | 08:05 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i think for 17s you might need like 38-40 psi
Old May 12, 2005 | 08:54 AM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Run what is suggested pressure on the tire.
Old May 12, 2005 | 09:51 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
15psi for all those hard launches when you need the most traction :reechy:
Old May 12, 2005 | 09:55 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
That is MAX pressure you should run, not suggested tire pressure.
If 15s I'm supposed to use 35-38psi. You want to increase it by 1-2psi for every 1" you go up. So for 17s it's +2 then you add 2-4psi over stock.
Autocross Help Page
Old May 12, 2005 | 11:56 AM
HeavyFooted's Avatar
HeavyFooted
That's what its all about
Depends on wether you are looking for that slight harder or softer ride and also if you are willing to sacrifice a lil extra tire wear. Around 40 psi plus or minus a few for a harder ride, around 30 or a lil more for a softer ride. I forgot which causes a slighty faster wear but i guess it's all about that sidewall flexing because that's what absorbs majority of the road condition. Being 40 series tires though, i don't think it really matters cause you don't have that much sidewall...around 40 psi is the ideal pressure you should have in your tires....
Old May 12, 2005 | 12:00 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
so what should the tire pressure be for a 205/50/15 tire? i usually put about 30-32
sorry to jack the thread homie.
Old May 12, 2005 | 06:13 PM
CivicSiRacer
Also more pressure will protect your tires and increase MPG.
Autocross Help Page
