Burning VTEC
Old May 13, 2005 | 02:55 PM
Sonik evolved's Avatar
Sonik evolved
Default Burning VTEC
I have the 97 d16y8 sohc vtec and it seems everytime i hit vtec i always smell the aftermath its like it was burning up the motor, i dont know wahts up with the motor i mean i have plenty of oil in the car and it almost happens everytime i hit it wtf is up? I drive regularly and keep good care of the motor i dont know whats up
Old May 13, 2005 | 04:40 PM
jweltch's Avatar
jweltch
Closet Ricer
I'm no expert on these motors, but all I can think of right now would maybe be a leaking VTEC solenoid?
Old May 13, 2005 | 09:37 PM
Kai's Avatar
Kai
Rotorphile.
The VTEC solenoid is on the left side of the back of the head. Even if it leaked while activated, it wouldn't drip oil on to anything hot enough to burn it.
Old May 17, 2005 | 05:40 PM
DirtyHarry's Avatar
DirtyHarry
Default ur block
maybe there is something wrong with where the oil squirters are, down in the block, and its getting up in through the cylinder bore. Non v-tec motors have no oil squirters down in the block. just an idea, but i'm no import mechanic.
Old May 17, 2005 | 05:42 PM
DirtyHarry's Avatar
DirtyHarry
Default one more thing
Go to the honda dealer and have the guy sitting on his ass show you the micro-phish on your motor. And ask a few ?'s about the oil squirters in the block.
Old May 17, 2005 | 06:58 PM
Illegal B16's Avatar
Illegal B16
New Zealand
sure it's not your clutch that stinks? Do a compression test and see what your at, and check your plugs to see what they look like.
Old May 17, 2005 | 08:07 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by DirtyHarry
maybe there is something wrong with where the oil squirters (...) just an idea, but i'm no import mechanic.
It's obvious you're not a Honda tech because that can't possibly be the problem.
Old May 17, 2005 | 08:10 PM
Illegal B16
New Zealand
Yep, a lot of the race (dohc) engines that get built around here dont even use the squirters anymore. They are track cars only for the most part though.
Old May 17, 2005 | 08:33 PM
DirtyHarry's Avatar
DirtyHarry
Default wrong
all v-tec motors squirt oil under the pistons to transfer heat away from the conecting rod and main bearings. Its inside the motor block.
Old May 17, 2005 | 08:36 PM
Kai's Avatar
Kai
Rotorphile.
First, It's VTEC. Variable valve Timing and lift Electronic Control. There is no hyphen.
Secondly, there is no way the oil squirters can cause this problem. Trust me, no extra oil is going to seep past the rings to burn due to the squirters. Hell, I don't think Y8's even have oil squirters. I haven't noticed them in the blocks I've seen.
