Burning VTEC
Old May 17, 2005 | 08:38 PM
Illegal B16's Avatar
Illegal B16
New Zealand
Originally Posted by DirtyHarry
all v-tec motors squirt oil under the pistons to transfer heat away from the conecting rod and main bearings. Its inside the motor block.
I was talking about full custom race engines not useing them, if you were replying to my comment.
Old May 17, 2005 | 08:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
D16Y8:
B18C1:
"one of these things is not like the other"
Notice #14 & 15 on the GSR motor? I don't see them on the Y8... h:
Old May 17, 2005 | 09:03 PM
bambbrose's Avatar
bambbrose
Originally Posted by Illegal B16
Yep, a lot of the race (dohc) engines that get built around here dont even use the squirters anymore. They are track cars only for the most part though.
That's kind of stupid. They are there for a reason and help keep things cooler. I mean for drag I can see removing them, but why take the time when all they do is help the engine out. For real racing nobody in their right mind would remove them
Old May 17, 2005 | 09:29 PM
westcoaststyle
My buddy that recently registered here will likely make 600+ whp soon and he runs a 10.9 @ 135. He removed his oil squirters. h: (B18C1)
Old May 18, 2005 | 12:28 AM
Kestrel's Avatar
Kestrel
Push to shock!
It was mainly for cooling purposes for the stock Honda parts. If you're using aftermarket pistons and rods, and they're big enough to transfer heat away, then the squirters aren't necessary anymore.
Old May 18, 2005 | 12:37 AM
EGteknikhatch's Avatar
EGteknikhatch
Team Teknik
back to the subject on hand. You need to do a compression test and leakdown test. While doing that.. Check your plugs.. Any oil? replace your valve cover gasket and all the donut looking ones. Then maybe tighten down all your bolts on your oil pan. theres some options for ya
Old May 18, 2005 | 05:15 AM
bambbrose's Avatar
bambbrose
necessary being the key word. With forged internals they might not be necessary, but they will still be beneficial.
Old May 18, 2005 | 09:02 AM
Kestrel's Avatar
Kestrel
Push to shock!
Depends if you're trying to maintain higher oil flow/pressure or not. Overall block lubrication/cooling may be more important than cooling pistons and rods.
Old May 22, 2005 | 06:21 PM
Kai's Avatar
Kai
Rotorphile.
That's kind of stupid. They are there for a reason and help keep things cooler. I mean for drag I can see removing them (...)
It's a long-term reliability issue. To get the engine to 150k miles, sure, they're great to have, but on a performance engine they aren't needed.
Old May 22, 2005 | 11:25 PM
bambbrose's Avatar
bambbrose
depends what the said performance engine's intended use is. Most people think drag, I'm thinking road racing.
high rpms for 20-30 min's definately are going to see a benefit with squirters
