Rear Sway,Tie, Brace
Old May 13, 2005 | 06:17 AM
KJJ's Avatar
KJJ
Drive Hard
Default Rear Sway,Tie, Brace
So I hear that if you use a rear swaybar thicker than 19mm you'll need reinforcement to avoid subchassis tear. That is the last thing I need. I’m looking into a 22mm sway/tie combo. Which is better, the tie or brace? Can/should I use both or is this overkill?
This car will see the track once a month and I’m pretty hard on it…
Old May 13, 2005 | 06:21 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you should use both but get the Beaks reinforcement kit to reinforce the chasis
Old May 13, 2005 | 06:38 AM
KJJ's Avatar
KJJ
Drive Hard
so the Beaks reinforcement kit wont interfere with the sway/tie combo
Old May 13, 2005 | 08:12 AM
teg92's Avatar
teg92
WHAT OK YEAH!
No it wont interfere in anyway
Old May 13, 2005 | 02:48 PM
drew935's Avatar
drew935
Laguna Seca circuit
I didn't use one. There's another brand that makes the reinforcements mounts as well. Just search for it. Here's a pic of mine.
Old May 13, 2005 | 09:40 PM
Kai's Avatar
Kai
Rotorphile.
"Tie bars" and "braces" are the same thing.
Old May 15, 2005 | 08:07 PM
KJMagnum's Avatar
KJMagnum
They are different. There are braces that actually bolt onto the subframe to reinforce it by giving more contact area. Here is a brace for my car: http://www.a-spec-racing.com/product1.php. Tie bars don't do this so they won't stop tearing unless you get a combo like this: http://www.comptechusa.com/store/140130.html
PS: The Beaks kit isn't all it's talked up to be: http://www.superhonda.com/forum/showthread.php?t=183381
Old May 15, 2005 | 08:27 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I have the comptech unit on mine. No worries of subframe tearout here.
Pic:
File Type: jpg
Old May 16, 2005 | 05:25 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Tie bar is a waste of money.
Old May 16, 2005 | 02:38 PM
KJJ's Avatar
KJJ
Drive Hard
OK, so it looks like I will be putting everything I can on the rear. I was looking at the suspension techniqes rear sway bar/tie kit and or the ASR brace or the whole ASR kit. But here's the thing, ST is 22mm(3/4in) and the ASR is 19mm. Which would be better??? I have a 1in sway up front.
