Turbo Update..... Problem
Old May 14, 2005 | 02:10 AM
Kabooki's Avatar
Kabooki
Default Turbo Update..... Problem
ok, i finally got the down pipe welded and the oil line taped. It sounds great when it spools. I am not running any boost yet, im still waiting for my intercooler and ecu chip. Problem is that now I get a CEL after driving random amounts of time. Every time I turn the car off, the CEL clears. How can I check what it thinks the problem is? Only things I have really messed with are the Oil Pressure sensor and the O2 sensor. Why would it throw a code after random driving times? How can i check the code?
Old May 14, 2005 | 02:15 AM
Kabooki's Avatar
Kabooki
custom downpipe :$125 watcha think?
and i must say, that looks sweet.
Please considder the following:
-I have never installed a turbo before
-I have only used HAN for Reference
-Other than the welding, ive done all the work.
File Type: jpg
File Type: jpg
Old May 14, 2005 | 04:32 AM
2gr84u's Avatar
2gr84u
2gr84u
take your car to autozone, they can tell you what code its throwing
Old May 14, 2005 | 07:47 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
http://www.c-speedracing.com/faq/03.php
Old May 14, 2005 | 12:06 PM
Kabooki's Avatar
Kabooki
They said they can only read like 96 or newer cars
Old May 14, 2005 | 12:10 PM
Kabooki's Avatar
Kabooki
Originally Posted by jeterkm02
I know how to do that, but it seems the code resets when i turn the car off. So when i short that connector there is no code.
Old May 14, 2005 | 12:38 PM
Kabooki's Avatar
Kabooki
ok, i did it again with a paperclip this time and got a code, 43.. << Fuel System???? I never messed with that. Im not running boost, so how could that have done anything?
Old May 14, 2005 | 12:56 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Could be anywhere between ure fuel tank to injectors. It's a soft code right? You don't lose power when driving? Also, where do you get the piping wrap?
Old May 15, 2005 | 01:40 AM
Kabooki's Avatar
Kabooki
Actually im losing a noticable amount of power loss when driving (i wont even try racing how it is right now) I got the wrap from local performance shop for $1/foot. But i found out its got fiberglass in it, and im still itching.
Old May 15, 2005 | 08:15 AM
Omniscient's Avatar
Omniscient
Just check the usuals I guess, like pump, fuel filter, and injectors. Might have a clogged injector, it happens.
