How to install LED M3 mirrors ?
Old May 10, 2005 | 08:00 AM
Civic_sensation's Avatar
Civic_sensation
Default How to install LED M3 mirrors ?
HEY!.....got a problem
i just got these M3 LED performance mirrors for my Civic 99.....and i would like to know if it is that hard to install them or i can do it myself......and if i can plz explain how.....i would greatly appreciate it......THANX
Civic_sensation
Old May 10, 2005 | 10:41 AM
Bricks2k4civic's Avatar
Bricks2k4civic
unscrew 3 bolts from behind the mirror, unplug it and take it off. Put the new ones on the same way. If it doesn't have a harness, cut the factory harness (leaving enough room to put it back on later if you need) and solder the wires together. There should be an extra wire for the LED's. If you are wiring it to the blinkers, just splice them in, or you can wire them to whatever you want. It is really easy.
Old May 10, 2005 | 11:15 AM
Civic_sensation
THX alot.....so basically the plugs for the led are gonna be there.....or do i have to like remove the door panel
Old May 10, 2005 | 11:18 AM
Omniscient's Avatar
Omniscient
warm butter on toast
Nah, you shouldn't have to remove the door panel, my friend put some on his show Ranger. It's pretty simple. I'm not sure what color the wire is on you're mirrors, his was the color of his headlight blinker wires.
Old May 10, 2005 | 11:22 AM
Omniscient's Avatar
Omniscient
Mirrors are mirrors.
Old May 10, 2005 | 11:23 AM
Civic_sensation
alright so when i remove the original mirror....the wires are gonna be there
Old May 10, 2005 | 11:30 AM
Civic_sensation
Originally Posted by mistacee
I'll say,The problem is you bought these mirrors.
I bought these mirrors at $ 2.95 on e-bay so i dont really care
Old May 10, 2005 | 11:36 AM
Omniscient's Avatar
Omniscient
The Ranger's were inside the actual mirror, but his were like 109.99$ not Ebay so I don't know. His came with color instructions.
Old May 10, 2005 | 02:12 PM
Bricks2k4civic
yes, if they are power mirrors, there should be a plug cliped to the door. If you have to cut the wires, the colors should match up. In my car, you only have to remove one small plate, then pry up a small part of the door panel to get to the plug. From what I've seen, yours is the same. The small plate directly behind the mirror just pulls off with a good pull. If you have to take the entire door panel off, there are about 3 or 4 screws, and the same type clips. As for the LED's, you can either extend that wire, run it through the fire wall and to the wire at the physical light, or you can find the circuit, and splice it from there.
Old May 10, 2005 | 05:08 PM
Civic_sensation
HEY! THX ALOT......THE GUY AT THE GARAGE WANTED 50 $
F****** rip off
THX
