- i need tiresss
- Eibach Lowering Springs
- Interior advice
- Transmission GRIND
- Check this out
- When checking CEL codes, the check engine light turned off.
- Lowering My GS-R
- O2 sensor-wires came unplugged, need help ASAP , please!
- Quick Intake Question
- Must be getting old...
- metalic buzzing noise resolved-I think
- What's the difference between the....
- Thickest Oil for a 99 Integra
- Angel eyes headlights for the poor man
- jdm interior
- wheels-interior- and suspension
- When brakes applied @ stop, pedal looses firmness
- wrecked my 94 ls . need help
- Integra ABS Codes
- NA parts soon, can't wait... NA update
- reuse oil filter a problem?
- Ouch.......Help!!
- Couple Of Questions
- Got ZEX...whats next? IM or drag radials??
- What Does GSR stand for anybody?
- Could someone do a carfax report for me?
- short shifter question
- noises
- fuel and cams?
- problem w/ my teg
- Strip my Integra!
- Wheel hub removal?
- Help!
- Changing out clutch needs to be bled?
- Help identify this wire
- water in trunk
- speedometer accuracy question on these tires
- Difference Between GSR and ITR Muffler
- how to install a spoiler
- aluminized exhaust piping?
- Rotor size, thinking about conversion
- stock ls header specs?
- Integra Rear Seat Removal
- Intake???Weapon-R..or AEM CAI????????
- Clutch Break In Period
- Question for you integra people :D
- Rear Sway difference frlom Tie down bar?
- Cl/RL/TL calipers on a Tegra?
- Major Service Coming...Advice Needed
- anyone with carfax?
- 98+ front end conversion.
- foglights.
- OEM Acura Parts?
- SRS-Airbags, will they fit?
- Slipping sound during acceleration
- custom exhaust
- Need Advice on Shocks
- 1300 for paint?
- Need some tail light advice for my gf's car
- Blown Head
- Brake Problems
- Hi, I'm new. Need some advice
- HID White bulbs
- golden eagle ls-vtec kit?
- is it time for new brake pads?
- Headlights
- Just got ZEX kit...what else do I need??
- Honest Opinion
- Type R Flywheel On?
- Spoiler question
- Significance of 9mm wires?
- Horn question
- Magnecor KV85 wires
- my base dyno run
- Bushing Install...How hard?
- turbo time and power locks
- New here.
- What do you use to clean windows?
- Power Steering Fluid
- suspension woes
- Fixing Cracked Tranny Case
- Ignition system question
- My Falkens R Rubbin
- APEX'i N1 VS GReddy Evolution
- My Car Burning Whitish Blue Smoke
- shift knob question
- tapping noise
- 95 GSR tranny problems please help!!
- Terrible noise when turning...busted LCA?
- Emblems Stolen
- LONG TIME Mitsubishi NUT turned Acura! Advise on GSR purchase.
- Energy Suspension Shock Bushing Set
- where to find oem 2000 integra type r service manual
- Pin Stripping
- Timing Belt
- Build Project to Begin!
- 5Zigen FN01R-C
- What do you clean your car with?
- transmission hum and axle loose....please help
- 00 Si tranny on 94 gsr
- Track Day @ Big Willow on Memorial day
- Idling too low
- Braille Automotive Development Battery Group Buy
- DC5 Rims????
- Ground Control Adjustment
- Exhaust smells like gas...
- Fog Lights?!?
- Car Takes A While To Start
- Will you get a second car and have ur teg as a daily driver.
- GSR exhaust tip
- replacing cam seal
- buy this header?
- Lower tie bar installation questions
- Measurements?
- painting stock sideskirts
- my friend cut my bumpstops
- Older Acura
- Setup for my GSR
- weird clusters
- spring/strut compressor problem
- 94 LS everyday driver
- How to make cargo lid for a 91 hatch?
- hondata s200 for 2000 gsr
- nitrous ????????
- too many miles?
- interior f'ed up from previous owner. what to do?
- Hondata heads???????
- metallic buzzing noise when start up /99 integra gs
- 1998 Vs 2001 Computer
- Windshield wiper problem...electrical?
- Carbon Creations Bodywork
- idle question
- ITR Pistons/Rods
- better handling?
- unsure about bushing
- shooping for tires
- CEL/engine problem
- Is this normal???
- Which color for calipers
- Help me solve coilover problem
- Car shakes when braking
- need measurments
- gas guage prob
- Not OT because I say so: Chicago ITR BBQ - May 15
- Are coilovers worth the money?
- largest tire size?
- Wont start
- Was this a good deal on my new 99 GS-R?
- Totled 95 GS-R
- AEM CAI Loose Mid-range Hp?!
- painting engine bay
- 94 ls, is 133k too many miles?
- broke a bolt! help!
- synthetic oil users, how often do you change your oil?
- might get an R
- dont know where to put this...
- HELP me quiet down my ITR
- New to Board Need advice on exhaust.
- some help purchasing, *cowars*
- Need some serious purchasing help!
- Carb Sticker for AEM Intakes
- PIC request: G3 w/SI rims
- HELP: Malfunction light came on and stayed on - checked manual already
- header variations, 4-2-1, 4-1
- New catalytic converter needed?
- Type R Header
- 2000 gsr setup plans
- Intake and Intake manifold compatibility
- turbo debate
- need help on header
- 98 integra gsr
- header instal need help
- Starting/Running problem --HELP
- Real HKS? have trademarks?
- Trouble finding Cold Air Intake?
- Backordered..
- Best turbo setup for a B18B?(ls motor)
- type R valve springs..
- head work, bottom end work too
- 2001 PY Type R project Phase 2 complete
- good brake pads?
- exhaust question
- uber hp mod
- all motor setup for 2000 gsr
- Dielectic Grease
- Will Integra Tokico Shocks Fit SI Civic?
- Steelies to SI rims
- help running hot
- Is a Venom 400 control module worth it????
- oil pan gasket replacement help
- tokico feed back
- spoon crates????
- trouble with summit cool hose
- Anyone delt with importrp.com?
- Wrx
- 4.40 final drive?
- Spring/Coil question
- difference between b18b and b18c rod's in length?
- Cheapo ebay camber kits any good?
- Cabin air filter...??
- clutch problem ?? i think
- online stores.. asap
- Short throw vs. long throw shifters
- need help with smog for my integra
- will a 94 bumper fit a 98?
- i decided to go all motor on my 2000 gsr here is my plans
- Best Tranny Oil?
- Best Exhaust/Muffler for 2000 Integra
- ebay camber kits
- black soot on bumper
- hardest shocks?
- bodywork and paint
- Black smoke out my exhaust and I need a smog check soon!!
- turbocams
- Factory Coolant and Factory Brake Fluid questions for ITR
- how to determine year of ecu?
- need more power, logical power
- Clutch adjustment?
- Good Deal?
- Help...stange noise
- Oil?
- Clutch Problem **Need HELP**
- Compression #'s are low
- Lsd
- Zeal Coilovers For Sale
- "Mugen Power" Gauge faces
- gas gauge screwy
- sidemarkers
- Fujitsubo Power Getter vs. RM01A
- I cant get my spark plugs out!!
- Boosted R's
- Are these good prices.
- Break Rotor Rust
- Not burning oil, no smoke, yet low compression? What causes low compressiom?
- LS/GS-R Exhaust difference?
- is this a great all motor setup
- throttlebody probs
- Place ur bets hear<------
- front turn signals, messed up
- HAN members: Falken Azenis Groupbuy 205/50/15
- Center cap inserts
- HELP!!! peeps
- Something sliding when turning right quickly
- Suspension
- building a ls/vtec?
- clutch/flywheel setup??
- TRACK and DYNO question!
- DC OEM carbon fiber hood owners...advise please
- Will 94-00 GSR rims fit on my 91 RS hatch?
