Idling too low
Old Apr 22, 2004 | 12:37 PM
maldini's Avatar
maldini
Default Idling too low
For my 1996 Integra(automatic), every time I step on the brakes the RPM would go lower and lower as the car slows down. It feels like it is going to stall since the RPM is very low, like a few hundreds. Why is it bogging down like that? Any way to fix it?
It also happens when I shift to reverse gear. It would go real low before rebounding somewhat.
However, I discovered that if the blow fan is turned on, the RPM would normally go slightly higher.
Old Apr 22, 2004 | 02:49 PM
rgbpmp's Avatar
rgbpmp
You can raise the idle yourself, if you search you probably can find the right rpm for your model.
When was the last tune up, how many miles. Maybe the pcv valve is crapped out.
Old Apr 22, 2004 | 04:50 PM
joebenz's Avatar
joebenz
nelson rules
could be distributer cap and rotor, or plugs.
no sig
Old Apr 22, 2004 | 05:15 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
Try doing a tune up first, if you still think your car is idling too low, than you can adlust the idle by adjusting the screw near on the TB
Old Apr 24, 2004 | 11:08 PM
pirate252's Avatar
pirate252
He wouldnt want to adjust the idle, since its only happening when he steps on the brakes...
I had the same problem on my car a while back, but it kind of fixed itself...it went away around the time i replaced the O2 sensor, but i dont see how that can be related, maybe check for a vacum leak or somthing in the brake booster line??? Or any other vacum leaks
Old Apr 24, 2004 | 11:16 PM
FA9S8U's Avatar
FA9S8U
I agree...with pirate 252 it sounds like the brake booster is loosing vaccume, somehow I would check the vaccume lines around it, my integra does the same...I havn't really looked into it but probably should
swtxaznrac3r
Vehicle Classifieds
2
Apr 19, 2004 01:48 PM
curryspeed1
Accord
9
Sep 7, 2003 08:17 AM
maldini
2
Sep 2, 2003 08:50 PM
icedog75
6
Jul 20, 2003 09:58 AM
rabican
Prelude
8
Aug 22, 2002 08:42 AM
