Spoiler question
I installed a 3 piece Spoiler, which make my trunk unable to hold itself up when i open it (really heavy), I don't know what you call that thing that holds it up...
Does anyone know where can i buy ones that's can hold more weight? so i don't have to keep on holding the trunk door when i putting stuff in?
Is it easy to install?
thanks,
thanks,
yours might just be shot... so id try just changin them first, get some used ones if you can find em in good shape.... i have a set from a 92 that are still tight.... check and see if they will fit your car, i will send em your way cheap.
Actuators are electric powered. Its the shock right? Should be one on each side, black in Color.
I dont think its the wing, because I have that wing too. I think one or even both are just shot
I believe they are known as "trunk stays" If your car didn't come with a spoiler (LS/RS) then the trunk stays aren't designed to handle spoilers. When I put an OEM spoiler on my LS, I had to switch to GS/GSR stays which were designed for spoilers. You can get stays at the dealer for about $50/side or you can buy aftermarket stays at most auto stores. Just make sure to get the ones for models that came with spoilers.
Originally Posted by teg128
that is what i might go for, but does it fit Integras? Thanks.
