- Having sunroof issues
- 5 th Gear Slip
- B16a2 Timing belt issue
- engine vibrates like its having a seizure
- Just installed HID...where does the 10amp fuse go?
- Hybrid Intake
- Custom Head Unit Mount...
- $800.00= New Suspension Setup?
- Front Wheel alignment (temporary)
- Loud faster clutch realease sound
- Fuel Managment for b16a
- 1994 Civic Ex problems. Timing Belt?
- oem fog light install
- Heater/AC Control Panel
- Upgrading brake master cylinder on 94 ex coupe w/rear drums..
- Installing Mugen side SKirts on 98 civic
- Post your 4 Door pics
- Strenth of Stock Head studs
- door trim help!
- del sol wheels?
- Anyone ever heard of this brand?
- Dropped with Eibach
- Help me make a decision guys!
- confused: garrett turbos
- Just about ready!!
- too tight. over adjustment or under
- Downpipe
- Impact wrenches - what to buy
- header problem
- Pulling Hard Left??
- finally new pics and vids of my boosted d series
- Loud Knock, smoke turns to bigger prob.
- 98 Civic ex coupe (ALT PROBLEMS)
- Squeaky clutch pedal
- starting car, and when car is warm
- evo piping size ?
- LSD or Non-LSD for B18C
- Thermal Research development exhaust
- compression ratio
- Which Engine
- Gauge Cluster
- Need help with ECU pinout
- TPS or IACV
- 96 civic bumper question
- Anyone ever had this problem with their camber kit?
- Coilovers
- ECU Tune
- my d16y8 is dead, what will fit in my 96 ex
- Oil Filter
- speedometer broken, is this what i need?
- Transmission Housing
- SRS Light is On what do i do?
- Foglight removal help...
- Welp.. time for a radiator, got any ideas?
- Rear speaker grill kit
- fuel gauge issue/dashboard fading
- removing decals\stickers from body
- rebuilding an older car
- where are engine motor mounts?
- might buy a car need help it ticks...
- shift knob threads...
- Question about foglights?
- Fuel System problems
- Is this legit?
- air conditioner
- looking at a hatch.
- Idle Air Control Valve, Location...?
- Rott
- clear jdm style headlights
- Motor swap project
- Electric Supercharger
- gsr power
- hondas holy valves
- Self HID Kit
- Zex system...need help!!!
- parking light size
- next step.
- Another stupid 4dr (black one) problem
- My new ideas (PICS!)
- Supro Rpm Gauge!!!
- Clutch question
- Blower motor does not run at all - 1993 Civic DX
- Well.....My car decides it wants to start now.
- Programing keeless remotes
- JDM rear lights?!?!?
- Been away from honda for awhile need some help...
- Headlight Problem
- Installation of a "APR performance wing"
- F'ed my Clutch Up
- Headlight wiring
- JDMsh!t.com OE Mugen Urethane Lip
- Key Won't Turn In Ignition
- OEM fog questions
- Repair of roof antenna
- How do u 92-95 hb like your ls?
- this is the worst day ever i swear!!
- Opinions please
- Need a battery
- need help choosing lower springs
- I need a Little more power
- need some insight...
- who uses synthetic and who uses regular
- No Power Or Top End
- Adjusting idle on 96 hx...
- alittle help here
- rear lip
- Blown d16 head on d15 block
- What could it be?
- Ok, well I had to push start my car again lookie inside
- 94 civic hatchback
- Can you guys answers a few questions?
- Opinion on tint for 2dr black Civic
- 95 Civic Thermastat
- leaking oil
- Where can I go to get production #’s
- 4 door compared to a 2 door 5th gen
- CRX ( Del Sol) Engine swap
- GSR engine but i have D16y8 gauges...need help
- 2001 Civic LX OWNERS!! noob question
- Alright well, I got all day tomorrow to fix these problems.
- the perfect world
- New Vehicle
- No heat --heellllllppppp!!!!!!!!!
- valve adjustment
- Good motor Info
- Trying to figure out what this damn guy did to my 4dr
- 99 civic climate control question?
- A little Horsepower
- Clutch!
- Common 99-00 civic problems
- fog light question
- Grinding noise from Tranny
- Sway bar setup- good combo?
- clear corner lights for my EL
- wondering more on b series swap
- Civic clutch adjustment??????
- 00 civic skunk 2 stage 2 cam
- exhaust question
- question about pedals
- Reason for my high vtec rpms?
- civic ferio with cvt tanny
- hmm what do we have here...Absolutely NO 56K
- 1997 Civic Back Seat Panel Rattles
- redline while clutch engaged
- Pushed her pretty hard this weekend - dyno results
- Motor mounts for a h23/h22 frankenstein swap????
- Car Smokes AGAIN! :MadAsHell:
- 2000 Civc Rear doors are closed and can't open. HELP!
- USDM or JDM GSR Swap
- 96-00 D16y8
- Compression test
- temp gauge is up then normal HELP IM NEW!!
- 16 or 17, size tires???
- Clutches
- running rich problem on 98 civic ex
- Crankshaft Weight Spooling good or bad?
- the 30 cent performance boost
- d16 non vtec head is same as d15 in book
- TBI. a looser paradise.
- AEM Cam gear
- what to buy ( just graduated :D )
- would headers from HX engine fit and work with non HX engine?
- How do I know if my civic is VTECH
- Lightweight Crank Pully? Need Answer ASAP..Thanks
- Civic Accessory Rims from '05 on a '00
- Smog question
- Programming Factory Alarm
- Power Steering
- Won't go into first????
- best way to protect a bare block
- How to adjust collum / steering rack...
- Where Can I buy a 99 SI shifter?
- BARO sensor problems on my 98 ex
- B Swap in a 94 EX
- b18b mounts/od1?? for a 1992 civic hatch
- temp gauge and speedo problem....
- Could I have a Bad catalytic converter????
- Ok, well. I'm still throwin 21 but my vtec works.
- CEL 7 and 20..............grrrrrrrr
- type R suspension for civic
- Head back on...engine races!!!!!!!
- Just had another stupid idea.... (TRADE!!!)
- um, this my be bad
- 99 civic SI ecu...
- which exhaust?
- civic exhaust
- 99 Civic Help!!!!! car cut off
- Finished My Swap. Pictures.
- Question about compression and leakdown?
- Good Compression with Positive Crank Case Pressure
- Ok, well I went to the Honda dealership.
- B20vtec owners, post your 1/4time and set-ups. That involves your tranny too
- quick intake question
- interior Mods
- custom apexi n1 catback?
- Question about engine and mileage?
- What engine?
- Locks for storage compartments don't work
- Wheel Offset?
- rear breaks
- Skunk2 rear swaybar
- check out my new shoes!
- Wideband Instuallation
- what kind of foglights are these
- exhaust advice
- Dc Lca
- So I notice some grey stuff near my shock tower.
- B16A2 head bolt torque
- lowering car
- vafc settings II
- new brakes
- What's that plate under the taillight called?
- Need help with skunk2 cam
- Integra Type R Muffler on Del Sol
- Need help finding Red/Clear taillights for civic..
- My review of the Korback frame locks
- Quick Help - Fuel Filter
- OK to put synthetic oil in high mileage car?
- Is turbo addictive?
- where to buy a decent bodykit for 98 hatch
- Please give your prognosis
- type R Color ?
- Dashboard removal
- 04 Civic kit?
- S20 vs S40 tranny
- i dont know anything about this???? HELP
- Are all 92-95 civic knuckles the same??
- Happy Swappin'
- I am gonna go N/A, I need some help
- Fastest Ever??
- 6th gen coupe/hb/sedan carpet differences?
- Maintenance on a 140k D16Z6?
- What Colors Do Ek Hatches come in?
- '94 to '96 Upgrade
- Too much for a 1997 civic cx hatch?
- Type R shift knob question?
- Turb kits?
- Hood
- stock suspension swap to EK
- Downpipe Drama
- speedo problem..
- Odd tranny/cv noise
- vafc settings?
- D16z6
- Please kill this turbonator thing with real experiences once and for all
- Just a Few pics of my OLD EG hatch
- 95 DOHC del sol shift linkages
- Engine switch Acura into a 92 civic DX hatch
- Repair a Sqeaking noise?
- B16A2 head removal
