93 civic misses.. ignition?
Have a 93 Civic that has a little sputter when the engine is under load. It only happens when the revs are under 3k. I've changed the cap and rotor (honda ignition is superior. simple yet powerful), plugs and plug wires. What else could it be?
it drops out form air fuel you are right. check your coil and make sure contact point is not coroded. If it is, sand it out and see if its better, if so replace your coil . If not then go to fuel disto. Disconect the fuel regulator from vacuum. If its smoothed out replace the thing. you need the stupid adapter to test pressure, fill the tank with pre. if it goes away replace the pump if not deal with it in a kindly manner
