Problem with dash conversion wiring
Old Jun 29, 2005 | 06:12 AM
Dcsmith84's Avatar
Dcsmith84
Default Problem with dash conversion wiring
I bought a wrecked 94 integra, and I am doing a dash swap into my 95 civic. The problem I have run into is the wiring for the dash. I am using the stock civic main wire harness and the integra dash harnes. I have read many threads about using the stock civic dash harness, but instead I am switching out the gray plug from the civic wire harness to the integra. So it will plug right into my fuse box. I spliced most of the wires in, but when I turn the ignition on, there is a fast clicking noise. Also the rear defrost switch stays on when the ignition is turned on. all the other lights and guages seem to work, except the rear defrost, and blinkers. The hazards work. but not the blinkers. Also the defrost switch light does not come on when I turn on the parking lights, while all the other dash lights do. I have looked forever to find a wire diagram for the fuse plugs, but all I can find is ones where people switched the guage plugs and rewired the hazards, rear defrost and blinkers.
If you know what I am doing wrong, please let me know.
Thanks
Dustin
