D-series peakboost
On stock internals. How much boost could i run with PeakBoost's D-series turbo kit(with fuel option) before needing to get larger injectors and Hondata(or other form of tuning)
ive heard not to boost no more than 8lbs on stock internals but of course you better have fuel managment for that...but before you do that make sure your motor is mechanically sound for that..id run 6lbs for awhile and if you have no problems crank it up to 7 and so on but dont pass 8.
run stock boost until you have better engine management and internals.
Originally Posted by smallphobia
So id be fine running stock boost till i could get better FMU and injectors?
yes. which turbo setup are you running?
