fan not working
Old Jun 17, 2005 | 03:26 PM
clinger17civic's Avatar
clinger17civic
Default fan not working
my fan on my 92 civic si is not kicking in. this is causing my car to overheat. ive tried hooking my fan up direct and it works so i know its not that, i also just changed my auxilary fan switch, thermosdat, rad cap, and rad flush. Does anybody have any solutions. This is pissing me off
Old Jun 17, 2005 | 03:48 PM
Civic2Scooby's Avatar
Civic2Scooby
thermoswitch...its in the thermostat housing.
Old Jun 17, 2005 | 03:51 PM
clinger17civic
thats the one that i changed i guess its just a different name!
Old Jun 17, 2005 | 04:31 PM
stereo's Avatar
stereo
unplug the fan switch on your thermostat housing put a jumper or paperclip on the contact on the plug , now turn the key on if the fan runs fine then it's the fan switch or thermostat/ lack of coolant in the housing try bleading the system. if fan does not run then check fuses and relay or ground connection
Old Jun 17, 2005 | 11:27 PM
randomtask77's Avatar
randomtask77
Wanderer
Could it be a faulty thermostat? If yours is stuck open, then I'm guessing the car's thinking that it's not reaching operating temp, so that's why the fan isn't kicking in.
Old Jun 18, 2005 | 06:44 PM
flatliner's Avatar
flatliner
Fix It
Default hey
on the head, under the distributor one wire. next to it 2 wire, replace and try again.
