Clutch Alignment.....
Old Jun 16, 2005 | 09:27 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default Clutch Alignment.....
Anyone knows what happen if the clutch is improperly aligned? I'm trying to diagnose my clutch engagement problem.
Old Jun 16, 2005 | 09:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like a failing clutch to me.
Alignment doesn't have anything to do with engagement. The clutch is aligned when the pressure plate is mated to the clutch disk so that everything is straight so the input shaft of the tranny will fit right through the disk and pilot bearing when the tranny is put back on.
Old Jun 16, 2005 | 10:11 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
it was a brand new clutch 6 months ago
Old Jun 16, 2005 | 10:22 PM
Provocateur
On permanent hiatus
So what exactly is the problem you are having?
Old Jun 17, 2005 | 06:28 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
i have a hard time engaging in 1st gear, when i realeas the clutch it studders-vibrates the car, I was thinking first it was motor mounts. But now it seems like its because the clutch is slipping a lil during engagement. A friend just told me it maybe an oil leak somewhere in there? I do notice there is oil on the bottom of my tranny.
Old Jun 17, 2005 | 06:00 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
haahahaha... oil leak?? WTF??? just replace the clutch and that will solve your problem...
the end!!!!!
Old Jun 17, 2005 | 06:31 PM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
Did you have the flywheel resurfaced when you replaced the clutch? If not that could be your problem.
Old Jun 17, 2005 | 09:14 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
An oil leak wouldn't have an effect on the clutch engagement.
Old Jun 17, 2005 | 09:30 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
rear main seal leaking onto the clutch?
Old Jun 17, 2005 | 10:06 PM
Provocateur
On permanent hiatus
That is what I am thinking. Was the clutch properly broken in? How new was the clutch when you noticed this?
