suspension techniques vs. comptech
Old Jun 23, 2005 | 09:40 PM
civicexstacy00's Avatar
civicexstacy00
Default suspension techniques vs. comptech
I've recently purchased the suspension techniques sway/tie bar combo and I was wondering if the setup is the same as the comptech version. Also, will I still need to get the subframe reinforcement kit?
Thanks
Josh
Old Jun 23, 2005 | 10:02 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, the reinforcement kit is always a great idea if you don't want subframe tearout.
The suspension techniques bar is probably identical to the comptech swaybar in thickness, but the tie bar that comptech includes is the best reinforcement you can get.
Old Jun 24, 2005 | 08:49 AM
civicexstacy00
That's funny that you say that. I just took a big look at both kits and the tie bars are pretty much the same and come between the tie bar mount and the subframe. The only real difference is the adjustability of the ST tie bar. I keep hearing that a reinforcement isn't need for the comptech, but if that's the case, why would it be needed for the ST kit?
Old Jun 24, 2005 | 10:23 AM
wilsel's Avatar
wilsel
If this is what you have then NO you don't need a reinforcement kit.
Old Jun 24, 2005 | 10:59 AM
Provocateur
On permanent hiatus
The comptech doesn't need reinforcement because it comes with the tie bar that reinforces the chassis. I assume that the suspension techniques bar that you purchased was just the bar and it WILL rip out if you don't reinforce the weak subframe.
Old Jun 24, 2005 | 12:27 PM
civicexstacy00
That is exactly what kit I have. Thank you!!!
Old Jun 24, 2005 | 04:15 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
original post says sway/tie combo :a:
Old Jun 24, 2005 | 04:24 PM
Provocateur
On permanent hiatus
Oh. Reading owns me. h:
Old Jun 24, 2005 | 04:39 PM
white_n_slow
it's my D in a B
happens to the best of us :chuckles:
