- Tilt wheel on my cx
- need help looking for motor or frankenstein info!!!!!!!!!!
- cat converter question
- wire tuck??
- Civic messed up outta no where..need some help
- someone recommend me spring rates!
- Dash/Corner/Tail lights stopped working - fuse is fine - please help
- I Need Help With My New Wiper Motor???
- smoking problem
- black tail lights
- 95 EX carpet replacement
- need suggestions =[
- Exhaust-muffler weld rusted
- Any Guesses
- GSR rear leathers in an EK
- how many o2 sensor located on engine B16A4?
- Stolen 1993 RHD Civic.
- Honda Civic MB4 EuroSPEC
- Honda Engine d16w4?
- dx seatbelt light...WONT STFU
- f22 into a del sol??
- mount question
- flowmaster on civic
- door panel clips...
- how can i test the o2 sensor??
- b16a2 and b16a4
- 96-00 Ferios
- Horrible Idle, help figure this out!
- b18 b15
- CX Gauges
- 99 Civic EX
- Does Civic LX 2006 Comes with Anti-Theft Radio?
- suspension question
- Does the p08 ecu harness?
- Water in Throttle
- rear breaks swap
- 93 DX dismantling
- Weird noises on my civic
- Civic Si fuel line's part number
- Windows '99 Civic
- suspicious suspension
- What is compression? (pistons)
- 18secFerio vs. the 1/4 mile track
- Springs?
- Which Engine is best for a 92 Civic Si Hatchback?
- Purge cutoff solenoid
- D15b
- Problems after fuel system cleaning
- Guage Clusters.
- Is this dangerous?
- mirrors for a 99 Civic
- suspension problems
- I'm throwing codes
- need help with wheel studs
- help aligning front end
- 94 civic ex swap B16a or B18C1
- Hytech Twin Loop
- valvue problem
- Doing brakes this weekend
- "feels" exhaust
- Well....Shes gone
- Honda Del Sol -92 Gearbox oil
- acceleration
- Rear discs for 95 EX
- type r vs d series build
- Axle removal
- Broken intake valve
- o2 sensor diagrams
- need an o2 sensor
- i eat because im unhappy, im unhappy because i eat.
- INFO NEEDED. WIll these fit?
- Chef's swap pics. 92 Si d16z6 to d15b vtec
- Taking Off My Exterior Door Handles
- should i should i not get an air intake for 96 civic!
- RH head light down
- help: car makes a rattling sound at idle
- map sensor question
- Honda / Acura speedometer and odometer accuracy issues
- Rear Disc Conversion
- jdm fog lights
- flashing lights
- 1996 Honda Civic LX sputtering : (
- Brake upgrades
- 95 civic EX needs help!!!
- 03 Honda Civic
- changing air filter
- New turbo
- 06 Civic rear bearing bad
- HELP! How to Replace a Civic Trunk !!
- interchangable parts for d16y7 coupe?
- what wheels should i get?
- LS b18 swap on EG6 what should i RUN...N/a or Turbo?
- Integra seats in eg
- 95 Civic EX sunroof
- Air Conditioner Surging more often now...
- '01 Civic slips out of 2nd
- how much would it be to install power locks???
- anyone modded a d16y7?
- 96 Honda Civic 1.4: Timing Belt
- Apexi turbo timer wiring...help...
- Installing power mirrors on EG
- Custom Touches to my EK
- need help with car system
- 98 civic ex
- Lost Lug nut key
- question
- 1999 Honda Civic
- door pannels+ dash
- Help! Window & Doorlock.
- question about switching clusters
- differences?
- Window, Doorlock,Taillight, and Moonroof. PLEASE HELP.
- d16y7 help?
- Door Hinges
- HELP!!! 95' Honda Civic Overheating
- Help...need advice on muffler replacement??
- Gas gauge fluctuations
- downloadable 95 honda civic manual
- Integra Fat Fives
- 95 civic brakes ( Nedd Help !!!!)
- 02 Manual shifting stiff as molasses!
- Car will hardly start (help)
- Do silverstars really burn out quickly?
- CEL codes?
- I'm back again!!!
- latest pics of the grocery getter
- mad....ugh
- need help NEWBIE...b20b with gsr tranny
- 01 Teg = 99 Civic suspension?
- rain start problem. weird smell.
- d15b vtec finally in the car
- black spots?
- what does it mean
- huge throttle body
- Struts & Coilovers
- Odd emissions?
- b16a compression help someone
- quick question on ecu swaping
- Need help to find out how to change 96 Honda Civic headlights...
- MAP Problems - No CEL
- need help windshield wiper motor broken
- How Do You remove the windshield wiper motor???
- Clean Engine Bay
- 98 CIVIC-Basically Stock- Can a good shop adjust Camber without aftermarket adjusters
- check engine light. Need Help Please!!
- 98 Civic questions
- 99 Civic Gauge Cluster
- short shifter question
- Silly question, but still relevant.
- keyless entry not working/what ,why ,how
- Hardcover Manuals
- Oil Leak Help w/01 Civic EX
- what about this turbo?????
- 97,000 Mile 2002 Civic EX Need Tune Up Advice
- 93 VX shift light! *searched*
- 99-00 Front lip...
- Ebay turbo kits
- Pics for teh build
- LS/Vtec cant rev!!!!
- Who wants it???
- front bumper ????
- Brake light
- Good price for motor?
- Catalytic converter housing falling off (picture)
- Help finding wheel center? 94 del sol vtec
- Weird Electrical Problem
- Tell me this isn't impressive?
- cel problems
- Need help with exhaust
- Whining noise from engine compartment - drove thru puddle
- Which Sleeves do you prefer?
- *PicS* X gonna give it to ya..updates...*PicS*
- Fully built head worth it?
- Blew out the rods!
- A question about D-series transmissions
- ABS kicks in at 6mph when slowing or accelarating from standstill
- cold air from ebay....yes,..no???
- bad alternator?
- HCP vs. Hasport
- i need help with my air console please!!!
- Help! Engine running fine then loses power/dies
- reset
- Weird noise...
- Spark Plug Threads, Gap
- The time has come
- Grease!
- Rear quarter panels (95 honda civic EX)
- Need help for Del Sol
- swap brakes front to back
- Need some advice for Del Sol
- Check Engine Light for 1997 Honda Civic
- Unstable Steering How to Fix?
- Gettin high on Octane
- Car Wreck!! Need Help!!
- idle problems
- best way to stiffen your chassis
- Does anyone know how to hook up led lights on side mirrors on a 98 civic?
- Can you figure out what car these headlights are on?
- lip kits
- engine mount question
- Help! dash lights fried?
- Quality headlights
- Muffler fit my coupe?
- Side skirt problems!!!!!!!!!
- so i broke down last night
- clutch slipping? Replacement costs?
- lowering my car
- Rims for Cheaper
- 99-00 Si Gauge swap
- Going to REF
- civ engine tick
- I want to lower my honda civic LX. Any tips
- adjust driver's door; it's hitting the fender
- Fog lights installed
- msd sci
- Finally got my new front bumper on!
- 16 or 17s for silver 00 civic
- civic need help
- Engine ping
- 97 Civic EX need some advice!
- 93' civic projector light problem
- stiff stuff
- auto - manual
- Tranny Shop?
- HELP - Surging pulsing lights
- Springs & Shocks
- Alarm LED Lights
- Suggestions for stripping vavle covers
- AEM Bypass Valve
- 93 del sol clutch noise when disengaed
- Who wants to see my baby CiViC!!!
- Thinking about a cold air intake, help!
- 93civic vtec or non?
- how much would you buy my car for?
- Throttle body spacer problem
- Injen intake install on 00 civic
- do you in the US have the acura CSX?
- Rear wing/spoiler 96 Civic EX
- Shocks adjustment help..
- Damn Ebay Foglights
- bumpy ride on stock springs/koni yellows
- Leak near review view mirror
- '99 Civic DX Automatic Transmission replacement..How To's? DIY's?
- reading cel codes 96 civic ex...
- Eg cluster need some help
- Swapping a cluster.....Need Help!
- Sales Questions / Numbers Man
- 98 d16y8 rocker arm assembly ???
