Acura EL Solo shifter replacement bushings
Old Feb 1, 2007 | 10:56 AM
SIR SLEEPER's Avatar
SIR SLEEPER
Default Acura EL Solo shifter replacement bushings
Hi guys,
I am in need of replacement bushings for my Solo shifter on my 2000 acura EL. The shifter moves around when in gear.
1st question, can I get bushings designed for a 2000 Civic?
2nd will the stock ones work with the aftermarket shifter?
I found this and I am wondering if it woud do the job
http://www.prostreetonline.com/sku/8-1602.html
please let me know, thanks
Old Feb 1, 2007 | 11:06 AM
dieneverknowing's Avatar
dieneverknowing
Not sure to the answer of your first question, but I used stock bushing when I put in a short shifter and it worked fine. I eventually upgraded the bushings and when I was swapping them out, I noticed both were the same size, just the different material. There may be different cases with different cars. but that's what worked for me on my civic.
