car won't start
Old Jan 10, 2007 | 06:03 PM
ill1458's Avatar
ill1458
Default car won't start
hey, i tried starting my car today after it was sitting for a few hours and it would not start. the car was turning over but it wouldnt start. could it be that there isnt any gas getting to the engine. when i push the gas pedal, it feels as if it doesnt have much pressure. what can i do to get it to start? thanks
Old Jan 11, 2007 | 06:19 AM
Bad_Religion's Avatar
Bad_Religion
turn ur key and listen if the fuel pump kicks on..
Old Jan 11, 2007 | 07:00 AM
ill1458's Avatar
ill1458
what sound am i listening for, and do i turn the key into the on position?
Old Jan 11, 2007 | 11:07 AM
Bad_Religion
turn the key to the on position, and listen under your back seat for a priming sound from the fuel pump.
Old Jan 11, 2007 | 02:39 PM
ill1458's Avatar
ill1458
is the priming sound like a humming sound that cuts off after a few seconds? after going back today i tried to start it again and this time it sounds weaker, and the lights on the dash go dim and the battery light flashes. could it be that i just need a jump?
Old Jan 11, 2007 | 04:09 PM
Bad_Religion
yea the humming noise is the priming, it sounds like your battery does not have eenough juice or your altenator is bad..
Old Jan 11, 2007 | 11:00 PM
ill1458's Avatar
ill1458
well i tried giving it a jump and it still didnt work, my friend suggested that it was either im not getting a spark or im not getting any fuel. i havent heard anything about the altenator. i will get that checked out thanks.
Old Jan 12, 2007 | 06:34 AM
civicburner's Avatar
civicburner
It sounds more like a charging system problem being that the battery light came on. If it is your alternator, then most likely your battery has been drained. When you tried to get a boost did you leave the cables on for a couple of minutes with the other car running before you tried to start your own car to charge your battery a bit? Also check for corrosion around the battery terminals. You'll want to clean it off if there is alot of it.
Old Jan 12, 2007 | 06:54 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Main Fuel Relay
Old Jan 12, 2007 | 08:02 AM
Line7's Avatar
Line7
Platinum Member
If the lights are dimming it can only be the alternator. Go to Autozone or Strauss, they'll check your battery and alternator for free.
