Mtf Leak??
Old Feb 5, 2007 | 01:50 PM
eg6lover's Avatar
eg6lover
Default Mtf Leak??
I notice ever since i installed my tranny back on, it's leaking fluid. I triend taking back out and inserting it back in. It's still leaking. Does anybody know what it can be? Can I do something to fix it?
heres the pic of where it's leaking.
Old Feb 5, 2007 | 01:54 PM
fathergoat's Avatar
fathergoat
:3
Leaking at the axle? There is a seal there and you may have damaged it when putting the axle back on. If that's where it's coming from I would try replacing that seal
Old Feb 5, 2007 | 02:00 PM
eg6lover's Avatar
eg6lover
how can replace the seal. i've noticed the black seal. if it's damaged how can i take it off. I have my old jdm tranny in the garage with that seal but i really don't know how to exchange it.
Thanks.
Old Feb 5, 2007 | 02:13 PM
fathergoat's Avatar
fathergoat
:3
remove the axle, pry the old seal out, tap new one it flush, replace axle. just buy a new seal, they're only about 5 bucks and you should not reuse the axle nut so you'll need a new one of those as well.
Old Feb 5, 2007 | 02:18 PM
eg6lover's Avatar
eg6lover
thanks i'll let you know how it comes out. thanks.
Old Feb 5, 2007 | 02:37 PM
CivicRacr's Avatar
CivicRacr
is there a crush washer on the plug? from the pictures doesnt look like there is one, get one if you dont also.
Old Feb 5, 2007 | 02:47 PM
eg6lover's Avatar
eg6lover
crush washer ? where does it go? m bout to go the honda dealer and buy the seal.
Old Feb 5, 2007 | 03:37 PM
CivicRacr's Avatar
CivicRacr
the crush washer is a one time use washer that goes on the bolt to prevent leaks. you can get them at the dealer
Old Feb 5, 2007 | 04:45 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, there is a crush washer on the drain bolt. It should be replaced anytime the bolt is removed. I believe it is the same size as the one used for the oil pan.
Old Feb 5, 2007 | 05:00 PM
eg6lover's Avatar
eg6lover
kool thanks.
