Rear brake conv. ???
Old Jan 10, 2007 | 04:56 AM
cmezum's Avatar
cmezum
Default Rear brake conv. ???
What parts do i need for a rear disk con. for a 97 civic ex? i can buy a rear gsr setup for around 300. is that to much? Here is a list of parts included...
control arms, knuckles, park brake lines, calipers with brake lines and discs
any info would be great.
Old Jan 10, 2007 | 09:38 AM
noscope101's Avatar
noscope101
Eg_93_CPE
Im not sure if i would pay $300, but i know you'll need a prop. valve off a civic si. The swap is pretty straight forward, i recomend changeing all the brake pads before you bleed the brakes and, make sure you adjust the parking brake cables while the car is in the air, it makes the job a lot easier
Old Jan 10, 2007 | 10:26 AM
Snoopy's Avatar
Snoopy
been there done that
fyi, all 94+ integra brakes are the same, except for itr's. with that said, you can find them cheaper at a junkyard.
Old Jan 14, 2007 | 08:22 AM
cmezum's Avatar
cmezum
Thanks!
Old Jan 15, 2007 | 07:07 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I used the rear brakes from a 90-93 integra :rick:
$300 is too much
Old Jan 15, 2007 | 08:43 PM
Excelmotorwerks's Avatar
Excelmotorwerks
u can use the ones off a 90 integ. you just have to use your stock rear lca's
