Speedo / Odometer accuracy
Old Feb 3, 2007 | 11:56 PM
Toy Civic's Avatar
Toy Civic
Default Speedo / Odometer accuracy
I've seen the info about the 02-06 Hondas having speedo accuracy issues and that a class action settlement was reached. It appears that the inaccuracy was 3-4%.
Here is more food for thought. This IS also a notorious problem with 1992-2000 Civics and 1994-2001 Integras.
Case in point. I'm the original owner of my 1995 Civic EX Coupe. When new, it had the 185/60/14 tires. I found my speedo to be off by 10% per the speedo dyno check I had done at the time. It was reading 10% FASTER than actual speed. For the first 7 years, I dealt with it and mentally compensated by going 75-80 MPH to acheive a true speed of 68-73 MPH. With this 10% inaccuracy this also brings into question the odometer readings.........racking up mileage faster, as well as false 0-60 times published in the automotive press.
For the past 5 years, I have had 205/40/17 tires, and my speedo and odometer accuracy is PERFECT.
HMMMMMMMMMMMMMMMMMMM!!!!!!!!!?????????
