h22a4 turbo problem
Old Jan 10, 2007 | 04:09 PM
guy_corey's Avatar
guy_corey
Default h22a4 turbo problem
ok here goes my buddy just picked up a 92 civic hatch. it has a fully buil h22a4 engine with a t3t4 turbo. we are having a hessitation problem, we replaced the plugs so far. now the boost is up to 10psi the fuel pressure is up to 38lbs, when you get on in 3rd -5th it sputters real bad cant get it to engage vtec cant reach the rpm. now i am a tech but not famillar with honda any knowlage at this time will help me.
thanks Guy
Old Jan 10, 2007 | 04:11 PM
Snoopy's Avatar
Snoopy
been there done that
do not boost with that engine in it's current state. make sure the ignition and cam timing are correct. what is being used for fuel and engine management?
Old Jan 10, 2007 | 04:25 PM
guy_corey's Avatar
guy_corey
we are running 93 octane it has an aem e management system
Old Jan 10, 2007 | 04:26 PM
Snoopy's Avatar
Snoopy
what is the ignition timing at the distributor? are the cams lined up at tdc?
Old Jan 10, 2007 | 04:28 PM
guy_corey's Avatar
guy_corey
when it idles it will run smooth then it will sputter a little bit then clear out.
guy_corey's Avatar
guy_corey
i couldnt check that it is dark and my shop is closed would there be anything else?
Old Jan 10, 2007 | 04:40 PM
Snoopy's Avatar
Snoopy
did you ever have the car tuned?
Old Jan 10, 2007 | 04:52 PM
guy_corey's Avatar
guy_corey
not to this extent.
Old Jan 10, 2007 | 04:54 PM
Snoopy's Avatar
Snoopy
well to what extent then?
Old Jan 10, 2007 | 04:57 PM
guy_corey's Avatar
guy_corey
i never done turbo yet ive done all motor. never got into turbo motors.
