Pulling the Engine
Old Jan 23, 2007 | 12:48 PM
uo959's Avatar
uo959
Default Pulling the Engine
Hey guys, I ran my 99 civic ex low on oil and threw a bearing. I am going to replace(or turn) the crank and get a new set of bearings and most likely rods. Do I have to pull the engine to do all of this??
Old Jan 23, 2007 | 01:01 PM
Snoopy's Avatar
Snoopy
been there done that
pulling the engine makes everything a whole lot easier when you have to measure rod and main bearing clearances. i would never reuse a crank that spun a bearing.
Old Jan 23, 2007 | 01:08 PM
uo959's Avatar
uo959
Can I pull it out w/o a "cherry picker"??
When I start disassembling everything how do I know where everything goes when I reassemble it??
Old Jan 23, 2007 | 01:35 PM
mberndt's Avatar
mberndt
It is stated in the Honda repair manual, and the Haynes I have, that the engine MUST be removed from the car in order to remove the crankshaft...
Besides, even if it could be done it would be extremely difficult... If not impossible...
You need a garage, an engine stand, and a cherry picker to do the work.
Don't know how else you could pull the motor safely without a cherry picker?
And don't re-use the crankshaft, get a used one for cheap...
But, honestly, if you are asking questions like "When I start disassembling everything how do I know where everything goes when I reassemble it??"
Maybe you should not be doing your own work...
Old Jan 23, 2007 | 01:38 PM
Snoopy's Avatar
Snoopy
if this is stumping you when it comes time to measure bearings you'll want to kill yourself. grab yourself a helms manual and read it BEFORE doing anything.
Old Jan 23, 2007 | 04:50 PM
uo959's Avatar
uo959
What all do I have to unhook to take out the engine??
Do you have a tutorial of taking out an engine or anything??
Old Jan 25, 2007 | 07:25 PM
jordanhxc's Avatar
jordanhxc
axels, fuel lines, air intake, all wires, the mounts...another thing* to add is that if you have a hoist it's easier to drop the motor out the botom of the car
Old Jan 26, 2007 | 04:51 AM
uo959's Avatar
uo959
How are the axels removed??
Old Jan 26, 2007 | 05:09 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
You have a lot of reading to do h:
Old Jan 26, 2007 | 09:09 PM
uo959's Avatar
uo959
Where do I do that at??
