View Full Version : '92+ Civic/EL & Del Sol
  1. LS turbo how fast?
  2. can you host my service manual?????
  3. o2 circuit wiring help
  4. Suspension Torque Specs
  5. clutch help
  6. 95 Civic DX wiring harness for B16A2
  7. will these parts fit a 97 hatch?
  8. anyone have stock 99-00 bumper?
  9. NewB looking for some info..
  10. Paint Job
  11. 96-00 coupe owners
  12. cost to repaint front bumper?
  13. new hood
  14. question about GSR seats in 95 coupe and 95 sedan
  15. What have you guys paid....
  16. Guage Faces...
  17. crappy idle problem
  18. ::Retard:: Modification help please
  19. que about stock speakers in 94 civ.
  20. Tint Color?
  21. LS turbo
  22. :( Airbag
  23. trunk sensor problem please help
  24. Friends Del Sol
  25. exhaust rattles
  26. Sohc <> Dohc
  27. Bumpa
  28. timing gun choice???
  29. Swap Questions
  30. Will Apexi WS for 92-95 coupe fit a sedan?
  31. HELP NEEDED! Aiming Headlights
  32. Need help on GLOW GAUGE FACE
  33. New bumper: Gap under the corner lenses?
  34. Bushing install pics
  35. Honda Dealership Owns My Lip
  36. Intercooler Intakes
  37. Anyone with AEM Pulleys...
  38. Dried out and brittle rubber clams for intake
  39. cf hoods??
  40. 2/3 door 5th gens....
  41. car stolen
  42. 5th Gen. Hatch bumper removal
  43. act stage 2 clutch...
  44. Have you seen this?
  45. new wheels, looking for info
  46. k20 in a 6th gen!! ** EK-K20
  47. anybody looking to get rid of a turbo kit
  48. going turbo, need advice
  49. Turbo B16A2
  50. '98 Stock Alloy Wheels
  51. close ratio tranny better?
  52. people on 17s
  53. will a 6gen dash fit in 5gen?
  54. koni yellow and ground control control installation help
  55. mirror relay?
  56. HELP!!!...rear suspension install...seized bolt<<<<<
  57. FERIO pics HOSTED! *** 56k can try ***
  58. tinting tail lights?
  59. painting clear taillights to match 99-00,..
  60. 02~03 Civic SI, angel eyes??
  61. 2nd-3rd gear shift grind
  62. Cleaning off the tires
  63. Intake Installation
  64. Where can i get a d16z6?
  65. Performance issue
  66. Help a fellow civic enthusiast!
  67. WTF is wrong with my car?!?!?!
  68. Specialty Products front camber kit questions...
  69. advan look-alikes?? where can i get em.
  70. support beam!! pics
  71. Inner door panels
  72. Top of the Engine?
  73. Looking for some advice
  74. 2003 1.7EL Headlights wanted
  75. Give me your 2 cents please
  76. ls motor
  77. Will 215/35/18's rub on a 98 ex coupe with Prokit springs?
  78. Tail Light Search HELP!!
  79. 2 Suspension installs [PIC documented]
  80. Integra front end on 92 HB ... HELP!!!
  81. New User 96Civic EX
  82. Pics of my ride. 96 civic ex
  83. ok is this a good...
  84. Turbo d16 t3/t4
  85. Give me your 2 cents please
  86. leaking oil.
  87. Map sensor for my b16 swap question
  88. crap gas mileage, why?
  89. for those of u with teg fuel pumps...
  90. Will a 99-00 Si Ice box fit a 95 EJ SR and bay?
  91. Stock radio security code...
  92. 1994 Civic CX Front Speakers
  93. Trunk fitting
  94. b18c sucks coolant
  95. Tein SS or flex
  96. how's this for a deal
  97. about right????
  98. Speed limiter
  99. welding question
  100. how good is redline oil???
  101. Need some Opinions.. Wheels and Exterior styling
  102. Tein SS setting
  103. Quick question...
  104. Maintenance Question
  105. boost or swap
  106. EK side skirts on a EG
  107. type-r intake cam?
  108. EG9 Tails
  109. Still Not Starting
  110. Shaving Front Emblem
  111. eg9/8 jdm conversion
  112. Painting Interior
  113. wut 96-00's have black dash?
  114. Looking for some advice
  115. Hey everyone! New guy here, I'd like suggestions for my setup please... (56k warning)
  116. rear sway bar
  117. new suspension
  118. Lower console filler.
  119. Holy Crap!
  120. Parts need for Timing belt replacement
  121. 99-00 coupe taillight swap
  122. when to change spark plug wires?
  123. hmm... new fuel pump.... still no go?
  124. Finding these seats
  125. how will i ship a body kit?
  126. shaking steering wheel
  127. quick disc brake swap question
  128. 5th gen JDM coin pocket
  129. I need some help for school...
  130. Who has the best deal for a b16a1?
  131. OBD 1 CEL codes...here....
  132. jdm B18C1 wiring help
  133. urgent timing help
  134. question about this picture
  135. Should I go carbon fiber???
  136. which out of the 3 options below do I pick???
  137. New stuff... UPS is teh suck
  138. 97 hatch lower front grill
  139. new clutch..cant decided.
  140. pissed
  141. Si vs GSR
  142. Will a 99 Sedan bumper fit a 97 Sedan?
  143. new paint
  144. 98 JDM GSR into 96 civic CX helps
  145. My green sol
  146. quick..what is cel 3????
  147. Integra Rotors on a Civic??
  148. Calling All Ex-Ricers (96-00 only) Need Help
  149. Car is burning oil... Can anyone tell me the cause?
  150. Clutch engaging in Neutral?
  151. got my helms today!!!
  152. hub rings for rota slipstreams on 2000 civic ex?
  153. turbo people need some help
  154. AEM install pics
  155. help with painting headlights
  156. B18C1 install
  157. D16z6 or d16y8 tranny?
  158. '99 Si factory exhaust fit '97 Civic HX?
  159. What's my engine model?
  160. *PiCs*made my own earth ground cables*PiCs*
  161. How much will a stock EX tranny go for and will a SI tranny fit in an EX engine?
  162. It's been awhile SOooo.......
  163. Can someone run a carfax on this?
  164. How do you put on Fender???? 96-00
  165. Civic B18C1 Times
  166. June Bugs
  167. Wheel Advice
  168. How much would you pay for 9900 OEM Fogs
  169. where to rent spring compressor
  170. post pics of gauge installs
  171. heat wrap....
  172. 93 civic hb gas tank leak
  173. GH3TT0 fab ITB's
  174. /////////////pictures\\\\\\\\\\\\\\
  175. what should I do next?
  176. Finally dyno numbers from 8psi EX coupe
  177. 99-00 Front Si sway bar
  178. quick o2 sensor question...
  179. VIS CF hood Pricing..?
  180. RIP David Ryan Jackson
  181. exhaust question?
  182. Dumb Stang owner
  183. a/c compressor
  184. nitrous install
  185. BYE BYE Carlisle Custom Compact!!
  186. tips on b16a1 install into a 5th gen civic-?
  187. So i have boost...
  188. Help with Exhaust
  189. Holy AEM
  190. 2002-2003 si
  191. Interior Colors 92- 95 Coupe?
  192. Carbon hood
  193. Tenzo R Seats
  194. Finally got my lowers painted! 56k No way!
  195. si engine pics
  196. can someone run this VIN# through 4 me?
  197. New goodies *Pix*
  198. this seems odd . . .(lighting)
  199. some goodies came in
  200. Carlisle car show pix
  201. Eibach springs
  202. Is this junk?
  203. Fenderwell Lining part number?
  204. Ferio Folks
  205. I need a fuel pump!
  206. GRRRR.....Bloody Car
  207. Buying used V-AFC
  208. B&M short shifter
  209. where can i buy full cwest kit?
  210. This guy's a MORON!!
  211. Front bumper.
  212. Could'nt resist such a good deal!
  213. its offical....
  214. 94 CX HB running a 10.93 (LOOK!, 56K BW) <------------
  215. 1998 Civic Si Coupe (EX in US) hard starting
  216. new *daytime* pics - ~1MB
  217. 00 Si Wheel Studs HELP!!!
  218. dc header?
  219. rsx motor in 95 coupe???
  220. Best place online to buy Honda OEM products?
  221. Locking Lug Nuts
  222. VTEC problem
  223. Need MAJOR Help w/OEM FOGS!!!!! **HELP**
  224. cx head vx dx head
  225. Everyone post ideas for NEW del Sol!!!
  226. Adjustable Lowering Springs?
  227. Suspension Upgrade
  228. GSR Rear Leather Seats
  229. what do you think of these?!?!!?
  230. 92-95h/b vs 99-00h/b
  231. Next mod for my car?
  232. I'm back, but........
  233. New here
  234. skunk2 camber adj and coilovers
  235. 92-95 2/4dr taillight detail........
  236. Parts??
  237. 96-00 trunk shots
  238. 99-00 4DR Taillight for 96 4DR?
  239. Ahhhhhh
  240. shock and spring installation
  241. Anyone here have the combo of DC short shifter and Apexi WS exhaust?
  242. Quick Question about a 95 Civic EX
  243. power window and door locks..color code.
  244. Where is the corner fuse located in 5G Civic?
  245. Help concerning B16a install
  246. zex install question
  247. Threads stats.
  248. where can i buy a 92-95 civic shell?
  249. putting 99 integra dash in 92-95h/b
  250. would this be a good investment
go
