tires
Old May 21, 2003 | 11:41 AM
96cpe's Avatar
96cpe
Default tires
got my tires the outher day. kumho 712's. compaird to the nitto 450 's there god like. picked 195/50/15 for 50 a pice .
Old May 21, 2003 | 11:45 AM
The Beav's Avatar
The Beav
i
you suck, my tires are 107 dollars a piece, those are good tires too
Old May 21, 2003 | 12:04 PM
fish's Avatar
fish
where did you get em cause i need those same size.
Old May 21, 2003 | 12:37 PM
96cpe's Avatar
96cpe
tirerack.com it costed 234.02 to get them shipped to my house.
Old May 21, 2003 | 12:47 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i'm still a little lost on the whole tire dimension thing. what would be the difference between 205/40/16's and 195/50/16's? i know the 16 is for the rim size....:thinking:
Old May 21, 2003 | 12:54 PM
Nelson's Avatar
Nelson
Administrator
205/40/16's are wider.
195/50/16's are similar overall height....
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Cliff Notes:
First number 205 = the width of the tire.
Second is %ratio of the sidewall height. so 40 = 40% of 205 = the sidewall height.
Third is the rim size, 16 = 16" Wheel.
And not to be a jerk but, it took me a while to comprehend this:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 21, 2003 | 12:55 PM
randomtask77's Avatar
randomtask77
Wanderer
Yeah... What he said.
Old May 21, 2003 | 12:59 PM
flipped cracka
thanks max. now, how do i know what's better for my car?
Old May 21, 2003 | 01:01 PM
Nelson's Avatar
Nelson
Administrator
Generally, if your car is lowered a lot, I would go with a narrower tire, that's what I would think... that along with the propper offset.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 21, 2003 | 03:51 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
For 16's I'd go with 205/45/16, even though 205/40/16 is the "correct" plus sizing, a 40 series tire is way to thin to ride on everyday IMO.
