will integra 94+ LS guage cluster work w/ my DX?
Old May 21, 2003 | 07:49 PM
EddieK's Avatar
EddieK
Default will integra 94+ LS guage cluster work w/ my DX?
i was wondering if the LS guage cluster would work for my 97dx hatch.
Old May 21, 2003 | 08:14 PM
Motohip's Avatar
Motohip
No way. I've seen people who did it with lots of modifications, but don't expect it to just bolt right in.
Old May 21, 2003 | 08:33 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
i have a LS cluster in my 96 DX,...its not plug and play,...there is soldering involved,..i would give you the site for it but its down at the moment,...you can see the pictures of it in the link in my sig,...it fits like ass in the picture because i havent bolted it in right yet,..oh its on the sleeper in my album
Old May 21, 2003 | 09:01 PM
Outxider's Avatar
Outxider
X-Motoring
i have a 95 geeser cluster in mines, fitment is ok, i made it look close to stock as possible and i didnt even swap the civic plastic over. yes there is wiring, i soldered every connection and double check before goin in. mines is zip tie in. ill get pics soon.
i used this diagram and it works perfectly, i just had to swap one wire on the teg harness.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
on the teg right side plug for the fuel guage.. I had a pin in the 13 spot and had to move it to the 14 spot... other than that it was perfect....
Old May 21, 2003 | 09:29 PM
Motohip's Avatar
Motohip
Just get a 99-00 Civic SI cluster.
Old May 21, 2003 | 10:31 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
i also have one of those in my other hatch
