View Full Version : '92+ Civic/EL & Del Sol
  1. Intake Manifold
  2. del Sol GS-R swap motor mount help
  3. b16a swap question!!!
  4. 03 civic tach wire location
  5. How to install powersteering on 95 Honda Civic Hatch
  6. noob stumped on map sensor issue
  7. Buzzing sound under dash when turn signal on
  8. what is this green hardness?
  9. main wiring harness connector
  10. need help about fuel injectors and fuel rail
  11. Need help on a 2000 CIVIC SI
  12. suggestions please!
  13. 1998 CX D16Y7 stumbling on hills
  14. Help please, b16A2 cam seals replacement
  15. New
  16. hey guys need help
  17. 2001 Civic EX Lowering. . . .
  18. California Smog Test
  19. Normal?
  20. Overheating while conected to obd2 inspection machine
  21. Circlip wont go in Ball Joint
  22. Rear brake adjusters won't work
  23. Side Mirror swap?
  24. just got my motor need with with harness
  25. how to bleed the clutch
  26. how to change cluctch
  27. Helpppppppppp plzzzzz!
  28. leaking cv joint
  29. 99 si won't turn over
  30. code 4 crank angle sensor 92 civic
  31. Civic wheel stud knurl size?
  32. HELP: Battery Light comes on then goes off...then on then off
  33. My 93 DX Project
  34. How many mpg for a tank?
  35. ITR Front Upper Strut Bar on a EK civic?
  36. just want to make sure
  37. Starting Problem Still!!!
  38. ITR Front Strut Bar on EK?
  39. 94 honda civic
  40. Tony's Hatch Project
  41. New Here
  42. Need Help Choosing Turbo
  43. ECM/PCM internal circuit failure
  44. Starting problems
  45. My dad and I want to build an EG...
  46. 95 Trunk Lid?????
  47. 93 civic ex coolant leak/long post
  48. Help brake hose leaking
  49. Need some help getting my civic back together!
  50. Need some help getting my civic back together!
  51. I fail!!!!!
  52. del sol axleback fit on an EG???
  53. recommend me
  54. turbo d16y8 simple question
  55. pvc valve draining oil????help needed....
  56. engine check light
  57. Ej8-what is that- looks like an EM1
  58. Power Window Poblems in 99Si
  59. civic radio backlight
  60. Upper Control Arms Help
  61. Exhaust vs Intake Valve Stem Seals
  62. vtec probs, still!!!
  63. halo install
  64. Intermittent Vtec
  65. Map Sensor + Speed Sensor FS
  66. 93 VTEC Question
  67. Quick question on suspension civic/integ
  68. Yay! I deeed it. AIR tools.
  69. Tire size question need answer quick!!
  70. need help civic 96 hb idle problem
  71. Hesitating at low rpms?
  72. 97 civic headlight replacement
  73. Obd ii
  74. Where to find High Output Alternator
  75. Timing Belt 1995 Honda Civic Ex 1.6L
  76. How much oil 99 HX?
  77. At a stop, the rev meter and car will rumble.
  78. Headlights
  79. Shift light in 96 DX
  80. Lost keys for Civic 1.5 Vtec -96 {3 doors}
  81. Frustrating Idle/Stall Problem
  82. 1993 Del Sol stalls, then runs fine:
  83. wiring help needed
  84. Repairing Coolant Drain Plug Threads,, Help?
  85. 96 SI SWAP need help.
  86. Noob question ; 94 Dx Hatch
  87. Dash dimming problem
  88. Mudflaps that will fit my EG hatch...
  89. My HX has alot of issues!
  90. need help on new swap..
  91. I seriously want to cry. Worst day of my life. (56k no no)
  92. KOni/ Gc custom spring rates???
  93. ride is crappy, shocks or springs?
  94. supercharging CTR engine pros/cons
  95. Code 15 HELP
  96. starting problem
  97. 97 civic and a 2000 civic problem deck
  98. Turbo crew: B16a2 GT3037 Turbo....what injectors?
  99. pull deck out, something burn and now no power? help please
  100. need help idle problem!
  101. help me ID this part
  102. CRV suspension bits on a 97 hatch?
  103. Brake pedal squeak?
  104. well we were slow as bawlz at work today..
  105. ODB1 to OBD2 GSR ?
  106. SRS light is on. HELP me shut this sucker off
  107. Rear Disc Conversion
  108. air bypass
  109. Wet Sanding
  110. what did i do to my car now.....
  111. rubbing issues
  112. cluster lights went out
  113. 1993 honda civic axle
  114. 93 D15 Head Change
  115. Obd Ii Code P1300
  116. aftermarket bumpers...good...bad?
  117. my new slim fan
  118. 98 civic idle surges when at a stop for a while
  119. Headlights
  120. Steering Rack Bushing
  121. HELP front control arm bushing.
  122. leak where sun visor used to be
  123. Problem with Cat.
  124. b16a head with b16a2 intake manifold question
  125. Eneos 0w-50
  126. d16y8 vtec probs !!!!!
  127. Changed mounts huge vibration
  128. rocker arm help
  129. Replacing Seat Belts
  130. Check engine code PO135
  131. Quick question about interior stuffs v.Tony?
  132. RSX Seats
  133. trouble locating gasket
  134. Commong for seal around oil pan to leak on old car?
  135. brake & rubbing problem ggrrrr
  136. help finding oem bumber
  137. help me identify this tapping!
  138. Going To Turbo, Have A Couple ?'s
  139. HELP with tranny leak ,civic 96 ex
  140. Lower control Arm and Intake help
  141. Transmission/Clutch Whirring and/or Grinding, Throw Out Bearing??
  142. A/C suddenly cut off
  143. Heater Does Not Work/No air
  144. Hey Mike...
  145. intro...
  146. Switch next to Sunroof switch
  147. hey hey
  148. question about P/S
  149. seat swap
  150. Possible Cat failure?
  151. Anyone Familiar with MSD 2 Step Rev Limiters?
  152. wiring
  153. Is my rear spring bad?
  154. 93 hatch relay?
  155. Valve Adjustment Nut - 10mm or 12mm?
  156. XM in 2004 Civic EX
  157. Engine Won't Start
  158. 98 civic DX PCV on a 98 EX?
  159. Critical: need Help Honda Civic 92
  160. power but not turning over
  161. 94 civic ex 5sp transmission noise
  162. need help installing back the stock springs
  163. Unknown cable. with pics... Do you know what it's for?
  164. Question about a Cat.
  165. anybody else running rear EP3 brakes?
  166. Ideas for strip/ road racin?
  167. Lowering Spring Problem
  168. New Brakes squeal
  169. relocating my O2?
  170. water cooled turbo adapter...
  171. Checking compression on a non-running motor
  172. tires... recomendations...
  173. A few shots of my hatch
  174. Update on my 98 civic
  175. Picked Up A Slut And Had Her Painted... :)
  176. New Clutch Kit
  177. '92 vx (D15Z1) runs rough, lots of codes...
  178. Ebay Short shifter. WHy You Should NOT get one.
  179. brakes won't stop locking
  180. Please Help !!! problem with engine mount. .
  181. Front lower control arm bushings
  182. new here, need help
  183. can anyone help?????? PLEASE
  184. VERY irritated with Honda Dealer need advice
  185. Civic gas per hour at idle?
  186. delsol/prelude steering wheels
  187. Idle issue
  188. Seized Brakes PLEASE help
  189. What do i got to do to add some rear sway bars on my 96 EX<????
  190. eg6 civic interior
  191. 1996 honda civic ex 2dr dashboard and overheating problems
  192. 1997 Civic preparing for winter
  193. DC5 master brake cylinder
  194. battery light on but still charging???
  195. 98 civic keyless entry problem
  196. Tein Super street weird height adjustment
  197. Wire Tuck
  198. Gasoline Octane?
  199. Replacing side mirror on 95 civic - pics attached
  200. Today is a sad day.. :(
  201. obx
  202. Thoughts on Oil Catch for Civic 98 Ex?
  203. need some help with EK ride height
  204. noise and smoke
  205. Aside from plugs/filter
  206. 95 EX VTEC Auto to Manual Tranny Swap ECU
  207. B20/vtec? What do you think?
  208. VSS, vehicle speed sensor, can it be repaired?
  209. rear caliper rebuild
  210. ok, vtec controller help. please
  211. Done With Audio, Want To Start Making Power
  212. a few questions
  213. Civic vx motor w/ P08/P28 or run the P07?
  214. Where can i get a good quality front lip for my EX?
  215. any advice for changing hood release cable? 96ek
  216. How safe is driving in D3 with a Honda?
  217. Noise when turing - save me from going to the dealer please!
  218. Whats correct idle speed? 92 civic ex 1.6L
  219. 95 Civic OEM Style Fog Light Question
  220. which energy suspension transmission bushings for a 96ex?
  221. looking for sparkly interior vinyl paint
  222. How to set ignition timing?
  223. Need advice on what to do with the @ Trannys I have
  224. My first attempt at powder coating
  225. Drum brakes help
  226. picked up a set of freebies today....lets play pick a color :D
  227. battery relocation
  228. Problems
  229. Problem after going through water
  230. paint stripped 2000 SI wheels. Clear coat them?
  231. Engine Hoist
  232. GSR transmission in my L/VTEC swa[??
  233. Which One Is The Power Steering Return Line?
  234. Civic hatch help
  235. broken odo & speedo. smog?
  236. 96 EX brake conversion questions...
  237. How to remove door windows in a 95 civic si?
  238. 99 Si Ecu reset- Which Fuse?
  239. Tranney grinding?
  240. Why would you buy an EG??
  241. i havent been on this forum in years. but you guys started me off!
  242. honda help............................. :(
  243. 92 civic ex 4doors on a 92 cx hatch
  244. HELP!!98civic ex goes in gear wont move but feels like in nuetral
  245. 96 Ex Car Alarm Install
  246. Sunroof is screwed...
  247. Good shocks on a budget for lowered car
  248. exterior door handle
  249. Need help. 92 EX 5spd won't start.
  250. Seats for a 94 civic ex coupe
go
