Computer in trunk?
Old Oct 11, 2009 | 12:17 PM
Bassman4461's Avatar
Bassman4461
Default Computer in trunk?
I own a 96 civic ex coupe that has been swapped from auto to 5 speed.While recarpeting my trunk I found what appears to be a factory installed computer that looks like the OBD1 thats behind the right side kick panel.Does anyone know what this is and what it controls?
Old Oct 11, 2009 | 12:37 PM
Shameinator's Avatar
Shameinator
is anything plugged into it? if not its probably your old computer from the auto tranny.
Old Oct 11, 2009 | 01:17 PM
Bassman4461
Idid the tranny swap myself and did not know it was there.I installed the stick ECM from the donar car and everything seems to work fine.Im just curious if i need the one in the trunk.It looks like a cool place to hide my audio amp.
Old Oct 11, 2009 | 02:21 PM
Shameinator
If nothing is plugged into then no you don't need it. I have owned two civics and worked on more than i can count and have had subs put in and never come across a computer in the trunk.
Old Oct 11, 2009 | 02:40 PM
Bassman4461
Its behind a molded bulge on the right side trim panel.It has plugs in it now but im not sure where they go Ill try n trace them out.Your probably rite,they most likely went to the shifter plugs for the auto trans no longer being used.Or could they control the ABS?
Old Oct 11, 2009 | 02:47 PM
Bassman4461
Car is a 96 civic EX coupe with power windows, ABS,power sunroof,doorlocks,cruise control,and factory ac added by me.
Old Oct 11, 2009 | 06:08 PM
Civic2Scooby's Avatar
Civic2Scooby
any chance we can get a picture? Are the plugs yellow?
Old Oct 11, 2009 | 07:13 PM
sherwood's Avatar
sherwood
I missed Sean
was it just laying in the trunk or was it hidden? It may be an alarm/ lojack box
I found my lojack box while installing stuff one day, I was pretty thrown off at first
Old Oct 12, 2009 | 07:49 AM
marvinp8700's Avatar
marvinp8700
if the price is fair
if it's on the pass side it should be for your abs
