View Full Version : '92+ Civic/EL & Del Sol
  1. how do you acess the ti=hird brake light
  2. brake shoes
  3. H4H bulbs
  4. Avon Tech M550 A/S Tires
  5. A/C removal
  6. 2004 Honda Civic Door Key Cylinder
  7. ys-1 serial number?
  8. Nitrous advice help me please
  9. tanabe G power
  10. 95 coupe seats
  11. b16 into 94 del sol need help
  12. Finally
  13. Online Resources - Updated 2/14/06
  14. 93 Civic JDM D15B Vtec
  15. civic muffler
  16. Compression test part II (ouch)
  17. Bumper Question
  18. help toruqe converter
  19. eg dome lights
  20. Radio Antenna Upgrade...
  21. Letter from Honda
  22. Need new legal bolt-on Cat =(
  23. my back speakers
  24. can i have my fans directly
  25. This doesn't sound right to me...
  26. Electric Impact Wrench?????
  27. 1990 Honda Civic
  28. Gsr B18c Swap.....
  29. Swap question d16z6 to d15b
  30. Cat Back System When Engine Swap
  31. B series starters.
  32. Small stuff for small budget
  33. Hey will someone belt me upside the head
  34. Looking For A New Or Used Exhaust For My 96 Civic Ex 2dr.. Any Sellers????
  35. 95 civic cold air intake
  36. Which camber Kit should I chose for my 95 civic?
  37. D16Z6 Swap Looking for Turbo
  38. motor problem?
  39. 96-98 bumper swap with an 99-00 bumper
  40. Help Diagnos this problem.
  41. dumb question, but w/e
  42. civic raditor
  43. Suspension help/ideas !
  44. Looking into getting a Del Sol
  45. New pics after 2 years
  46. SI and EL headrests...
  47. steering
  48. BuBBle to teg help?!?!?!?!?
  49. Programming multiple keyless remotes for Civic '97
  50. More on Oil Filters - Civic
  51. Headlight Question:
  52. planning on the k
  53. Would this HID kit be easy to install?
  54. The 50 dollar project
  55. need help
  56. 95 civic ex d17a2 swap ????
  57. Need help with 98 civic ft bumper hardware
  58. wtf
  59. Volks Are They Worth It????
  60. turbo kits
  61. charger
  62. 96 Honda Civic Ex
  63. can i fit 03 si seats in my 2kgsr
  64. civic b16 question.
  65. O2 sensor from D16z6 to d15b
  66. what kinda cams should i get??
  67. need help
  68. What is the biggest wheel radius...
  69. P28 with D15B instead of P06?
  70. b16a2 compression test
  71. Question on engineharnes
  72. matching up headlight wires..
  73. need some info
  74. Honda-Acura.Net's 2006 Chicago Auto Show Coverage
  75. civic tranny help
  76. Brake set up?????????????
  77. Silencer
  78. where can i buy h22a parts online?
  79. which Civic?
  80. Type R in a EG
  81. Type R in a EG
  82. window crank/regulator Q
  83. brake swap
  84. Emergency brake problem
  85. gsr hatch
  86. i need cheap 16" rims for Civic EX
  87. Omni Coilover swap
  88. How HOT? turbo mani/exhaust mani
  89. omni power quick clutch master cylinder
  90. HELP Needed !!!!
  91. problem shifting
  92. Finding Specific Rim And Tire help Plz
  93. my lca
  94. Swapping seats on a 95 Civic EX?
  95. HELP with installing halo headlights on my 95 civic
  96. Automatic Transmission Fluid Change 2001 EL
  97. uneven brake pads wear
  98. Cold Air Intake Question
  99. HELP: fix dome light so that it turns on when door opens
  100. Should I be concerned with this? Pics
  101. b18a and b18b's
  102. Valve Cover Question
  103. CW lip on TW body
  104. 89 civic
  105. bleeding clutch via sucking through a tube?
  106. Possibly a dumb question
  107. Question EBay items
  108. Future Turbo Setup
  109. (na) B18c@200whp
  110. removal 98 civic 2dr. rear window?
  111. removing rear seats from eg hatch
  112. My Motor
  113. civic LSI low power
  114. Skunk2 Stage 1 Turbo Cam
  115. 2006 Acura CSX
  116. lsvtec setup.
  117. Rim Size Help
  118. JDMshit "Type-R style" lips civic 96-00
  119. Test drove a new Civic Si
  120. Jun performance
  121. bogs when cold and gauge cluster cuts out
  122. please help
  123. fuel injector, Throttle body & fuel rail cleaning
  124. how to change the indicator bulbs?
  125. help iwth tire sizing and choice
  126. D16z6 to d15b
  127. Lowwer front control arm
  128. How do you....
  129. **CIVIC STOLEN: Tucson, AZ**
  130. Ls/Vtec problem...any ideas??
  131. Weight of a d16z6
  132. New Brakes
  133. I need some ideas please
  134. Big Letdown!
  135. My hood is destroyed.....turnpike accident
  136. rotors question
  137. 95 EX steel wheel lug nuts work with HX rims?
  138. eg hatch back wide body kits?
  139. pulleys......and their side effects
  140. ECU problem
  141. Damn Good Clutch
  142. Integra seats on Civic
  143. i have the next dumb question.custom plastic speaker enclosures,like n show cars
  144. 2000 Si Build-Up Questions: Part 2 (newbie questions.. beware)
  145. p3o ecu
  146. power boost valves
  147. lowering springs
  148. winshield wipers...please help
  149. Civic Ls Swap
  150. 1998 Civic EX Service
  151. HELP ME: finding vin on engine
  152. brake proportion valve
  153. Anyone know what wheels these are
  154. LS swap wiring
  155. Chrome Signal Light that flashes Amber
  156. Boost
  157. Radiator W/ 2 brass outlets on bottom WTF?
  158. I wanna make my car faster
  159. help help pics of bottom end thanks
  160. why is my clutch pedal not coming back up
  161. Looking For Parts
  162. Question: Will a Type R Integra Crank Fit in a 1.8 LS block
  163. 15x7 +35 offset wheels on a 96-00 civic.
  164. Honda civic 92' 1.5 charging problem
  165. CIVIC EXI help
  166. Maryland/D.C. Honda Civic owners ?
  167. Exhaust System Questions
  168. G28r Turbo, Do i need to change fuel system when installing a turbo system?
  169. 1995 CX steel wheels - 13" or 14"? If 14", fit 95 EX Coupe?
  170. 96 Civic Need to change oil pan.
  171. How do i find out what engine is in my car?
  172. Auot to Manual Parts
  173. d15-d16 ....perfect setup
  174. coupe seats in hatch
  175. Transmission Questions? Important
  176. i have a question about my d16z6
  177. I was wanting to get a CAI...
  178. Im having trouble
  179. Lowering?
  180. RSX seats in EG?
  181. is this a good price for a civic??
  182. need some help *pics*
  183. will an EK hatch catback fit on an EG?
  184. how much horsepower should a 93 civic ex have?
  185. civic HX transmission question
  186. starting to get turbo parts, is this what i need?
  187. Valve Spring Question
  188. Dyno charts?
  189. Uneven Tread Wear, Alignment?
  190. i get 23-28 mpg on my honda civic ex, what should i be gettn?
  191. know where i could swap my 1.6 sohc ?
  192. How does a regular 1.6 Sohc differ from a 1.6 Sohc Vtec?
  193. 02 sensor problem...Help!!!
  194. I hav a 97 Civ Ex What mods should i choose
  195. Question about, Ignition signal, is it 5 volts or 12volts? On 96-99 civic si B16a2 (w
  196. Suspension set up compair
  197. civic 1994 ball joint
  198. need to find cheap parts...don't know where to look
  199. New Civic Si rims
  200. Need help please
  201. I'm back... (Bought an EG)
  202. TurboS?
  203. FREE TURBO question
  204. Good price??
  205. Fixin it up.
  206. Need Some Serious Clutch Help
  207. will ek hatch seats fit in an eg hatch
  208. Gauge Cluster
  209. My new Mod for my EG
  210. Help!
  211. hot fuse
  212. Doing a tune-up on my car today.
  213. VIN Decode for 1992 CRX Coupe
  214. Gen 1 Legend collector will pay for your stuff....
  215. axle fit in tranny
  216. in desprite need of answers on my "d16z6"
  217. Header information
  218. 1997 Honda Civic DX
  219. Question
  220. Altezza tail lights
  221. Engine swap Anyone From Pittsburgh Pa?
  222. Strut bar Problem
  223. I have a D15b7....i need help
  224. ebays new gimmic..... magnetic gas saver?
  225. Radiator Problems AGEN
  226. CX hatch, GSR engine, EK harness!?
  227. LOW redline
  228. do cam gears make a big difference or not?
  229. oooo the choices....
  230. EK's with Eibach sportlines?
  231. civic eg window problem
  232. Problem with 03 Civic Door lock
  233. QUick Help Needed(These Cars Good CHoices for 1st Time buyer???)
  234. D series flywheel 22lbs to 8lbs....
  235. 91 Honda Civic
  236. b18c1 GSR.........
  237. differential noise?
  238. 95-00 Civic Hatch
  239. Check This Turbo List...i Need Feedback...
  240. Hi Everybody !
  241. civic rims???
  242. Question About A Turbo Xs Kit????
  243. can i swap a vetec head for my SOHC 1.5 civic head
  244. b16 from 00 si into 94 cx
  245. Hey help I have D15B ?s
  246. Accord Turbo Problem
  247. Replacement center muffler?
  248. Tranny Fluid
  249. Tranny question????
  250. more clutch questions..
go
