problem with tranny/clutch
Old Feb 27, 2006 | 04:57 AM
Nicaraguense13's Avatar
Nicaraguense13
Default problem with tranny/clutch
i think my cars clutch split my car was running fine until i kind of pulled hard on 1st gear then i stopped at a light the car was fine but it had a little shake to it then i started moving it entered 1st like always but it started telling me check engine and 1st and 2nd were weak very is this a clutch problem i need to kno if not is it tranny i highly doubt tho because it a basically a new tranny but if it is please say so it gets into gear in ease 1 2nd and everything
Old Feb 27, 2006 | 04:58 AM
Nicaraguense13
please respond to this asap
Old Feb 27, 2006 | 02:43 PM
2gr84u's Avatar
2gr84u
2gr84u
well you wouldnt throw a check engine light if its a drive train problem, so that check engline is a completly different problem. Perhaps you could rewrite your question using sentences and period so that someone could better understand your problem
Old Feb 27, 2006 | 06:58 PM
Nicaraguense13
ok sorry was very shaken by my car being disabled. well i was driving and i kind of burned out on 1st gear for a couple of feet got grip dropped the gear went to neutral cuz of light. while i was waiting it was shaking a little bit and making a click noise. when the light turned green the check engine light appeared and the gear was weak like it was slipping alot. i think it might be the clutch can this be true sorry for the mis typed 1st post
