Blinker Issue
Old Mar 13, 2006 | 06:25 AM
jokeintegra's Avatar
jokeintegra
Default Blinker Issue
Replaced the drivers side front blinker! The blinker stays solid the whole time?
Old Mar 13, 2006 | 07:01 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Did you put an 1157/2057 in there? If you put an 1156/2056 in then it would likely stay solid all the time because it's a single filament bulb. You need double filament for it to work properly. Just a guess based on provided info...
Old Mar 13, 2006 | 09:10 AM
jokeintegra
yes there are 1157 piaa bulb installed. The rear blinker blinks really fast! The front stays solid? Thinking its a wiring issue!
Old Mar 13, 2006 | 11:58 AM
Running925's Avatar
Running925
Your Powder Coater
humm.. blinker fluid comes to mind..
sry, i had to ..
i'm gonna bank on snaged wire to the front if you have the right bulb in
Old Mar 13, 2006 | 12:04 PM
jokeintegra
gonna replace the harness cuz the last owner cut the wires and the wires on the socket dont match the wires on the harness! WTF!
Blinker fluid..... Ill try that next time Lmao!
Old Mar 13, 2006 | 01:25 PM
westcoaststyle
And now we have the rest of the story. h:
Yes, replace the wiring...
Old Mar 13, 2006 | 01:41 PM
jokeintegra
Havean idea what i would have to spend and what harness I will need?
Old Mar 13, 2006 | 01:42 PM
westcoaststyle
Just get a test light and rewire it. You said the wires don't match up so match them up...
Old Mar 13, 2006 | 01:50 PM
jokeintegra
yeah I meant they dont match up at all and I would like them to so I have to get the new wire harness!
Old Mar 13, 2006 | 02:01 PM
westcoaststyle
Or, use a test light and determine which wire is hot when your parking lights are on, and which is hot when your blinker is on. If the other side works then you have a template to refer to.
