i need help in replacing my axle?
i need help in replacing my driver's side cv joint axle. if some1 could help me i have a 97 civic ex and pics would be great of step by step also.thanks
warm butter on toast
So do you want help replacing the CV joint or the axle? Replacing the CV joint would cost less but it would take a lot more time than a 15 minute axle replacement. WCS did a DIY on a clutch job but also shows you how to remove/replace an axle. It's the same for pretty much every Honda motor. It's up in the online resources.
Originally Posted by V-tech powered
so i can replace the whole axle and it comes with the cv joint does in it? so that way is less work and its all new.
Yes. Get the axel at autozone. It's cheap and they give you life time warrenty there.
