Ignition Troubles?
I have a 92 civic 1.5 dx model with some troubles. While driving my car just shut off. Ever since then I can't start the car. Here is a list of things I've noticed checked. Thanks for any response.
Plug Wires have a reading of <25,000 ohms (around 12,000 ohms).
While hooking a timing light to each wire I get no light while turning the engine over.
Icm, primary, and secondary coil readings are in specs according to Haynes Manuel
My first and third spark plugs had oil all over the outside.
I replaced my plugs to check for all 4 fouled plugs.
Battery connects were checked and cleaned for connection.
Distributor Cap looked fine.. there were no build up/corrotion on coil or rotor or any other part of the distributor.
current status... stuck
Thanks everyone...
Thanks everyone...
