Problem
Old Mar 2, 2006 | 06:47 PM
Nicaraguense13's Avatar
Nicaraguense13
Default Problem
I posted a thread before about a problem i had about my car. I threw the car in first kind of burned out and got to the light i dropped it 2 neutral. when the car was stopped it was shaking alittle and then i went and my check engine appeared. would this be the transmission or would this be either the clutch or flywheel??? please respond asap to this because i juss finished taking out the tranny and need 2 kno
Old Mar 3, 2006 | 01:49 AM
NOSkweezePSI's Avatar
NOSkweezePSI
Well, considering you just put the tranny back in, the best case scenario is that the vibration from the harsh launch just knocked a few sensors or wires loose or perhaps you are just low on fluid. If it were my car, I would find out what kind of check engine code your ECU is throwing and go from there. Personally, I dont beleive it is your flywheel or clutch. Good luck.
Old Mar 4, 2006 | 12:47 PM
kidd_honda's Avatar
kidd_honda
Good answer. Yeah i would say check engine code. Hope this helps:
Check Engine Light (CEL), what do I do?: http://www.c-speedracing.com/faq/03.php
Check your Check Engine Light (CEL): http://www.c-speedracing.com/faq/06.php
Define your Check Engine Light (CEL): http://www.c-speedracing.com/faq/05.php
Check your Check Engine Light (CEL): https://www.honda-acura.net/forums/sh...d.php?t=185065
