View Full Version : Integra & '97-'01 Integra Type-R
  1. Radiator on 91 Integra LS 2 door
  2. Overheating while idle.
  3. Front Brakes Dragging Need Help
  4. 2door integra five seats?
  5. 1991 Acura Integra Under-voltage
  6. Coolant/Antifreeze Problem
  7. shock squking sound
  8. main relay AKA fuel pump relay
  9. >> Theft Alert: Py Itr Chicago 9-11-08 <<
  10. HELP!!! 3rd Generation Automatic Sedan
  11. Question on replacing window.
  12. Please help identify....
  13. overheating problem
  14. gsr/type r parts
  15. test pipe
  16. bad day help?
  17. What brake kits are good?
  18. Rear brakes scrubbing
  19. fuel pump relay
  20. I need a quiet catalytic converter.
  21. Which one?
  22. Possible motor swap
  23. '97 GS-R Oxygen sensors
  24. $800 for belt replacement?
  25. 91 integra abs question???? help?
  26. Dead Battery
  27. 92 Civic susp/brake parts on 90 Integra?
  28. Stallig out mid-drive. Help.
  29. Good site to order clutch?
  30. Crank Pulley
  31. gsr sway bar
  32. Integra 00 ...won't start after storm?
  33. 98 headlight with 94 bumper anyone ????
  34. B18 auto transmission removal?
  35. Fluid change help
  36. 98 Gsr??
  37. ITR power folding mirrors help pls
  38. new here, integra type r for 6k?
  39. how can i remove the wheel nut?
  40. hoist points for my b18b1
  41. integra type r
  42. Gl-4 Gl-5?
  43. Timing belt went out :(
  44. 90 Integra Oil Pan replacement
  45. Squaking Noise?!
  46. Camshaft not turning
  47. integra gsr turbo help!!!!!
  48. 95 integra red line cut off
  49. too much compression...help!!!
  50. Valvetrain Removal?
  51. 92 Integra Trans and staring issue
  52. OEM Flywheel vs Lightened Flywheel
  53. Oil leaks
  54. I've got $1,500 to get my Integra painted.
  55. Engine swap resulted in loss of power.
  56. another dumb question
  57. starting
  58. Integra Type R ECU
  59. Rotor Screws
  60. Need help
  61. need help with glow gauge
  62. 1998 White GSR Stolen - Dallas area - Recovered a day later.
  63. Regrease Front Wheel Bearing? Need a Press?
  64. idle question
  65. rough idle?
  66. Rubbing Sound When Driving - Not the Brakes
  67. my car smokes and burns oil fairly quick. i need help
  68. Integra Type R Cluster
  69. thinking of buying
  70. 1990 Integra GS idleing problem
  71. Stolen: 1989 Acura Integra - Baltimore Area
  72. 01 gs fuel gauge inaccurate
  73. ***Spec R's first build thread ever!***
  74. Integra LS turbo
  75. Tutorials on taking off panels in 96 Integra
  76. Common oil leak?
  77. Where's a good place to get tires mounted and balanced in the SF bay area?
  78. 2000 ITR - black smoke, need advice
  79. Thief got into my 2000 gsr
  80. front springs
  81. 92 GSR antenna problems
  82. Oil Cooler?
  83. exhausted - for 92 gsr
  84. Observatons while driving my gsr @ highway speeds
  85. 92 gsr - should i fix it, or ?
  86. 98 Integra Air Conditioner Compressor Replacement
  87. LS spoiler vs ITR spoiler ?
  88. Camber on 1994 Integra GS-R
  89. Ordering parts
  90. gsr strut tower brace
  91. gs-r feedback
  92. '95 Integra Musty AC Smell
  93. b16a swap troubles HELP!!!
  94. integra ls91 alternator problem
  95. Turbo advice wanted
  96. 1990 integra problem
  97. Code 22- VTEC Oil Pressure Switch
  98. 95 integ ls stock radio code?
  99. gsr downshift ??
  100. 95 gsr problem
  101. Help!!!!!!!!!!!!!!!!!!!!!
  102. Gas leak?
  103. How do you install an oil pan gasket so that it does not leak?
  104. Missing bolts!
  105. Odd Screeching Sound. Steering?
  106. Engine Revs on 2nd to 3rd Shift (AT)
  107. Is the Vibrant Axle Back Exhaust worth buying for a 2nd gen integra GSR?
  108. 92 Integra GSR
  109. Body Kit Hardware
  110. Help: My 1990 Integra didn's pass SMOG NOx
  111. syntheitc oil?
  112. Spare Tire Mounting Braket Welding Question for the real car builders out there
  113. for sale help
  114. 2000 GSR Susp. Question!
  115. wierd, but just go with me on this
  116. Gen I A/C System Capacity?
  117. On A 1998 ITR Head....
  118. ignition heeeeelppppp!!!!
  119. dash Clock read 1:00 Why??
  120. Integra Mid Pipe Question
  121. halo headlight
  122. suspension questions...
  123. Major Brake Problems....Please Help
  124. Knock sensor problem!
  125. Gen I Timing Belt & A/C Conversion
  126. Sway bar bushings
  127. 90 Integra RS Wont start after shut off... Wait. Then starts.
  128. does anyone know?
  129. annoying exhaust leak
  130. Going Turbo!!
  131. ABS System - Code 1 Subcode 8
  132. b18a1 vs b18b1 HELP!!!
  133. 95 LS sometimes has trouble starting
  134. do the 1997 integra ls brake rotors need to be pressed on???
  135. overheating problem...water pump?
  136. vtec and non vtec manifold?
  137. CAr WOnt Start NEED HELP ??????
  138. dashpot? air boost valve?
  139. want to buy but oh soo confused
  140. 2001 GSR Headers
  141. exhaust manifold bolts
  142. Tach-O-My bad...
  143. Spare tire mountian
  144. Speaker Wire to the doors???
  145. TPS Sensor 95 ls
  146. Been A while...
  147. 91 Acura Integra I blew up something but don't know what it is
  148. first mods????
  149. gsr vs ls/v-tec
  150. needs help!!! o2 sensor plugs on 97 gsr..
  151. Recommendations for replacing the radiator for 00 Integra GSR
  152. Rear Seatbelts Wont pull out
  153. Dead Gauges
  154. Just Became A Vendor!!!!!!!
  155. Changed Fuel Pump - Now no Spark????
  156. thread to replacing axles?
  157. How could turn off the ABS Light on gauge cluster?
  158. 2 pin map sensor
  159. Aftermarket tach stays at redline. . . help..
  160. Door trigger wire
  161. Loud crash sound when i let off the gas. Need Help
  162. smooth runing engine
  163. 90 Integra : Replaceing Gas Tank. Replace fuel pump?
  164. Recent fender bender!!
  165. Idle Surging... Out of ideas!
  166. Seriously considering getting my Integra painted. Need some shop referrals.
  167. help me [96 Integra, loose belt]
  168. My GSR NA Rebuild
  169. used greddy sp2 for integra ls
  170. AZ Emissions Help Please
  171. help i just bought 96 integra...went to register it and it came up with salvage title
  172. integra mesh wheels
  173. Interior break down problem!
  174. changing transmission fluid
  175. Shooting for 425 whp.
  176. 95 gsr: coolant in cylinder 1!
  177. What do you call those trim clips
  178. 92 Integra auto to stick conversion
  179. 1990 Integra Needs New Motor
  180. Help with electrical issues!
  181. Where is the OBD data plug?
  182. Trouble Code 65??
  183. Timing and breather filters
  184. 93 integra OBD port location
  185. Disappearing oil
  186. Wrecked 1996 Acura Integra
  187. Fuse Keeps Blowing Need HElp
  188. Sunroof Problem with my new GSR.
  189. usdm type-r
  190. I just bought 93 integra misfiring
  191. Clutch squeak, changed master/slave cylinders, still not helping.
  192. Help With Egr Valve
  193. Paint and body work
  194. in need of a b18c series head
  195. Exhaust problems
  196. what's the cause
  197. Son broke 2001 OEM taillight, car fails inspection
  198. So, my car failing smot = bad cat :oh:
  199. My suspension is P*SSING me off advice plz
  200. Rear Trailing Arm Question
  201. Back in the Honda Community..1st post
  202. Im poor!!!
  203. Broke Diff Housing 90 Integra
  204. DA swap
  205. Bad CV Boot/Axle?
  206. Evaporative Control Canister??
  207. Type R vs S
  208. Are these good?
  209. B16, CEL 1, new o2 sensor, same problem...
  210. Newbie Question, Oil Change
  211. Tach-o-my god
  212. Shaking when I drive
  213. simple question
  214. Quiet GSR Header for Gas Mileage
  215. Am I being scammed? Firestone replaced distributer, now recommend Crank Sensor!
  216. header wrap?
  217. ABS Issue
  218. OMG supension issues maybe?
  219. Emergency, car just broke down! Please Help.
  220. Swapping auto for 5 speed
  221. Clutch problem
  222. dc headers
  223. Sketchy Advance
  224. I turboed my integra
  225. CF Spoon Style Front Lip
  226. 95 acura turn signal/running light problem...
  227. car question V.battery?
  228. Identify this clutch noise (.wav attached for listening pleasure)
  229. I need help with putting on new power side mirrors
  230. Drivers headlight issue.
  231. Integra´90 walbro fuel pump installation
  232. 99 Integra driver side door lock sticking
  233. 99 GSR keyless entry problems
  234. Does Integra have Mass Airflow sensor
  235. coolant leak...need help!
  236. new gauges
  237. Can someone help me with a Cold Air Intake installation?
  238. Auto VS 5 speed
  239. wire tuck questions
  240. Newcomer to the self repair scene
  241. Ignition And Injection Problem
  242. 92 GSR leaking Power Steering pump
  243. Anyone Know?
  244. should i install the new exhaust before i lower my car?? [Merged]
  245. fuel filter
  246. Question about lowering a Type R
  247. Requiem for a machine bolt: DC Integra owners take note...
  248. Need Help 91 Integra problem
  249. Clutch options?
  250. wired trans issue i think?
go
Search Engine Friendly URLs by vBSEO 3.5.2
