GSR Gauge Cluster Lights
F#%K JDM, USDM FTW
The lights in my '95 GSR's cluster are really dim. I messed with the little dimmer knob, and even when it's on full they're really dim.
Like if I'm on a road with a lot of steet lights, I can barely see the gauges lit up.
Is there a mod or anything I can do so they're brighter?
if they're really dim, something else might be up...i guess the only way to tell is if you compare it to another stock integra. maybe they're just really dim and you cant do anything about it
DB Squad
Integra Forum Moderator
DB Squad
F#%K JDM, USDM FTW
I talked to a friend and he said it may be the dimmer switch. I'm going to see if I can pick one up from Acura tomorrow when I got for fluids and try to get a case of oil filters.
If so, it is probably the dimmer switch like you mentioned.
F#%K JDM, USDM FTW
Going to get a new dimmer and see if that helps.
