OEM Exhaust Question???
Old 10-22-2008, 05:20 PM
tonamal
tonamal's Avatar
Default OEM Exhaust Question???
hey i just acquired a free 98-01 gsr oem catback exhaust with cat still attached.....will it bolt up to my 95 ls? if not what mods are necessary to make it work?
Old 10-23-2008, 10:16 AM
Spec R
Spec R's Avatar
i always forget what fits what...but the main difference will be the length of the B-pipe where it meets the cat. theres a difference between the 98-99 and the 00-01 GSR exhausts too if i'm not mistaken.
DB Squad
Integra Forum Moderator
Old 10-23-2008, 02:11 PM
tonamal
tonamal's Avatar
i just found out its from a 01 gsr....i know the cat is different but the rest i cant tell..might have to just put it on and see.
Old 10-23-2008, 02:36 PM
Spec R
Spec R's Avatar
well then it wont fit for sure. i have a 97 GS with a 01 GSR exhaust and a lot of chopping was needed but the best way to know for sure is to just bring it to an exhaust place and let them work it out for u
DB Squad
Old 10-24-2008, 06:49 PM
i used to have a 00 ITR muffler hooked up to a 5zigen exhaust piping on my old 94 rs sedan h:
the muffler didnt fit perfectly :hs:
Old 10-25-2008, 10:04 AM
ADRONICUS
www.ufc.com
ADRONICUS's Avatar
It won't bolt up. Fabrication is needed. No biggie. A cut here, a weld there and a chop there usually does the trick.
Old 10-25-2008, 11:53 AM
tonamal
tonamal's Avatar
yeah but the question is is worth paying someone to do that or to buy a new catback like the greddy spt. Either way i have to buy a new cat.
Old 10-26-2008, 01:34 AM
ADRONICUS
www.ufc.com
ADRONICUS's Avatar
That sort of job should run you no more than 50 bucks at an independent muffler shop.
Old 11-08-2008, 06:55 PM
tonamal
tonamal's Avatar
the exhaust bolted right on...from the cat to the muffler with no fabrication...thx for the help...
Old 11-09-2008, 08:34 PM
2001TEGGSR
2001TEGGSR's Avatar
From the cat forward is where things are different. Glad it was a bolt on affair, that always makes thing easy!
