- Shark Attack II Installation Question
- sup fellas, new here
- Porting gsr im......?
- Noise from driver side front wheel...?
- Weird...
- 92 Integra Dash Board
- check engine light
- VTEC wiring help
- Omnipower camber kit DIY up
- Please help me identify this sensor:
- Gearing
- turbo obd2 cat
- Help with cylinder head...bent valves?
- Consendation on headlights, what to do?
- vafc 2
- Need help with valve clearance!
- • Integra FAQ Thread: Reformatted and Generally Spiffed Up.. READ IT!
- clutch slipping or tires bouncing? nooooob Q
- Getting Closer
- Improving gas miles...
- Steering?!?!?!
- Removing/Replacing Head
- Need to replace heater control in 95 Teg, have ???'s.
- old squeaker
- What ECU to use
- TPS Adjustment Help
- Cel Code 54: CKF Sensor? On a 98 GSR
- Integra Rails And Mounts
- 90-93 tegs, what kind of trannys do they have?
- Timing Belt Install - Helpful Advice Requested
- vafc2 install...HELP!!!!
- Sudden "jolts" when driving
- making oil pressure prior to start-up
- Trunk Light
- G2 climate control temp. knob won't work
- Underdrive....
- Integra bad clutch or tranny?
- Exhaust Valve Problems
- no big deal
- Turboing my Teg.....
- Electrical problem - no clock,radio
- New ITR H-A member
- run switch to start car so cannot be stolen
- My new teg
- turbo question
- new greddy BOV???
- car is 90 percent done
- Integra Hesitates
- Help! Integra won't Start
- NGK BKR7E on a stock DC4 (99LS)
- replacing the thermostat
- What are some symptoms of worn Axles
- Induction kit question???
- Quick G2 exhaust question...
- Integra Trunk.
- Intake resonator removal
- R Oil
- 8 lbs flywheel
- Reverse Not Working
- replacing engine splash guard?
- upgrades
- New Cams,Valve train, pistons
- Rims or Clutch?? What would u do?
- buying 1990-1992 any suggestions?
- Obd1
- Cheap Tires
- Hey, whats wrong with your back tire?
- Power steering problem?
- type r door panel
- online acura parts dealers...
- removing power steering
- the radio code, do i have to pay?
- new muffler
- 99 GSR-T PROBLEMS! Here are some Codes Its throwing
- fuel requirements for gsr?
- How many miles should a an OEM clutch last?
- '97 JDM Front end conversion
- Do most of you guys just get 2 new front tires instead of all 4?
- Gearing Specs
- b18a1 and b18b questions for you
- TB and Intake Manifold Issue
- stock gsr clip
- 99 integra ls - best cold intake?
- Introducing myself
- after installing aem v2...
- Apexi GT Header
- Rs*r Gtii Cat-back Exhaust System
- Running without a muffler.
- New to forum-New to Acura
- Burning a lot of oil very quickly. Please help!!!
- Automatic shift selinoid problem
- growling and bucking....
- '89 Integra Engine Swap
- New to the Site
- Getting Exhaust
- Does this car have abs?
- Question about Flywheel's
- Loud New Fuel Pump
- Will a 94 AEM cold air intake fit a 91?
- 99 GSR Turbo - What is the Spark Plug to use?
- Need help...What workshop manual do you recommend?
- Stock to AEM SRI. How much more noise?
- 87 Integra alternator
- tail lights not working
- Burning Oil?
- Please Help!
- Snow in NY
- tyype-r ECU help
- 90 integ floorboard
- Bmw 330 Vs Itr
- My overly optimistic plans for summer '05!
- Timing belt Change Cost
- Well, I did it...
- need help fast - coolant gone!
- Integrated Control Unit
- Carsound converter, help.
- 1997 Acura GS noise from the rear of the car
- cheap hid's
- GSR Integra. High RPM when clutch pushed in
- CA People...Still Need Cat Help
- LS/VTEC ECU help!!!
- Header-Back Exhaust Questions
- Specific connector...
- Lifter Nut question
- Greddy vs. DC Header
- Gonna dyno my R on Saturday....wish me luck
- this car is getting on my nerves!
- 93 Intgra + No Spark No Start
- upgrade or not
- a poor, sputtering turbo b18c
- Iporting from japan
- Cheap Mods
- Bad Engine Mount
- Neuspeed race spring height and pics
- Lowering Springs/bigger wheels or both
- How to pull codes&cel lights on 98 integra?
- thunk
- got serious problem with my b16a head need help
- Taking off 90-93 Integra Steering Wheel
- itr runs funny after a long drive
- Weapon R Header any good for 95 SE?
- 98 GSR Floored in 4th at 90 - 100 MPH. Engine Noise Question
- Landspeed racing?
- sorry to bother u guys again...ice box questions???
- throttle body
- pistons for gsr?
- dragging brake
- turboing
- rim offset question
- Woot!
- weird blower motor problem
- Greddy evo or evo 2
- Where to get JDM GSR gauge cluster for 94' GS-R 4DR?
- brake pads people!!! WHICH??
- Type R intake manifold for GSR?
- AutoX/track turbo application
- Exhaust Silencer
- Tanabe
- meets/events
- What brand caliper paint?
- '91 teg won't start
- 3 problems: Door's Light Indicator, Passenger Compartment's Light, and Trunk
- Camshaft Removal Help Urgently Requested
- does anyone make a decent ITR short ramm intake???
- Brake Master Cylinder
- H22A Motor turbo?
- poor gas mileage
- itr parts for sale and performance itr parts as well
- Funny idle at start up.
- ac belt help! workin on car right now
- Redoing Wheel Clearcoat
- So I finished my first piston ring replacement...
- Powdercoating the fat fives??
- Type R in the salvage yard?
- best headers
- Considering buying GS-R, Need help
- Exhaust System?
- Catalytic Converter Gaskets
- ADR rims not DOT approved - what does this mean?
- 96-00 Tein s tech civic springs
- Who Knows The Most About R's????
- oil pressure info needed
- Turboing GSR
- High Idle on 94 teg. cantt pass smog
- Failed Smog
- PCV valve on B18B1.
- A-pipe buzz fix
- jdm itr recaro seats
- no o2 sensor bung on dc header..
- ITR Exhaust purchasing...where to buy??
- cat back install rust issue
- e manage dyno
- Apexi WS on GS?
- ITR with rims pics
- Axle back for 99 GSR.
- Tranny compatibility
- GSR S80 Tranny
- hey im new here...
- what type of exhaust should i put on my 01 itr
- New Here and would like advice on Integra :)
- Why won't it spray?
- antenna doesn't retract
- Integra turn signals
- What makes a VTEC a VTEC ?
- strange leak
- ABS question
- Question of cosmetics.
- My da integra keeps over heating , Help Please?
- Danger putting 23mm rear sway bay in NON-Type R Teg??
- Changed hose and thermostat gasket now won't start
- Bronze or Silver on Silver Teg?
- Cool little diagram....
- Tec-nique.
- Sluggish throttle response.
- help with an engine swap
- Best place online to get genuine Honda/Acura parts?
- Fuel Filter
- Whats the next step?
- integra gsr - what exhaust? - rsr exmag?
- Wheels stolen - where to get replacements?
- LS/Vtec or GSR?
- What size rims
- Suspenssion upgrade?
- clutch/flywheel on 91 GS
- Another tire thread
- Brain Fart
- rocker pannels?
- replacing fender on 97 integra LS.. bolt on or some welding?
- 1994 Integra sunroof / headliner
- GSR tran
- Non-Lowered Integra is bottoming out - Need new Shocks or Struts?
- Shifter Problem
- Any help with check engine mystery?
- Questions on Engine swap and taillight swap
- Are LS and GSR rotors interchangable?
- ITR Axle Back Muffler ?
- Silver DC with Red GT3
- how to read a vin
- door panel
- Concerning chevy map sensor
- ITR owners check in
- Shaking issues
- More issues...
- Smog Test plz help!
- VTEC and some oil burn off: Why?
- Tire Problem on my Teg
- itr rear sway bar
- Loose rear bumper
- Bad paint job?
- Head Lamp Problems
