- E-brake question
- Window Problem NEED HELP!!!
- 25,000 mile oil change intervial?
- tires and rims
- Skunk2 Coilovers
- Weird Rattling Noise
- '96-'00 Civic sunroof rattle squeak
- 3rd Gear Grind
- interior help
- What is the Catalyst System consist of?
- I think i my hae a prob.
- Transmission -- Come off dammit
- OBD Questions
- Painting FMIC?
- Does the OEM/factory wing on the Del Sol...
- Coilover Question?
- measuring height of Civic?
- front end question
- 98 civic A/C
- Adding horsepower to my 99 EL?
- Vtec Wiring
- Spindle Nut -- Come off dammit
- 94 civic center trim panel installation
- Need help with fuel level sensor
- Between how many miles do you change the oil on your Civic?
- lookie here
- Engage Clutch Question
- Decent/inexpensive mods?
- Just a few questions
- If you have an aftermarket exhaust on your sol...
- Need help on breaking in a 2005 Honda Civic.
- seats question..
- Bumper Repair.
- pcv valve location??96 civic SI
- Rear window spoiler....?
- vss in 200 honda civic
- Suspension Question?
- werd
- Because I hate y'all...
- Na is Better Shirts, and other ones
- Working on older civics(my 1993)
- B18B firing order
- Del Sol or Civic Advice Needed!
- Tuning Guide
- Pic Request, back of engine.
- Non-adjustable camber OK????
- Timing Belt Change causes oil leak?
- Good Bye Hatch - Pictures
- Old model restoration
- rough running swap
- 2004 civic si short shift
- Revive my 92 Civic DX Sedan?
- Tein Lowering springs
- odd engine noise, 00 civic ex
- FCC ID number for 99 Civic ex remote?
- 94 Civic concerns... NEED HELP ASAP
- 2001 Civic LX
- wheel help
- Question about an unpainted fender??? Pls help
- Help! Programming 99 Civic EX keyless remote!
- Check Engine Light?
- Any Good Cheap Camber Kits out there???
- Brake Pedal
- My Lights! Help Plz!
- Horn/Cruise/SRS failure?
- Heat question
- Your experience with Progress Springs
- Radiator Fan Problem 94 DX
- Knock sensor needed or not?
- Starter problem?
- 2000 Civic - Electric door not working...help
- Rims for my Sol
- Del Sol Cruise / Defrost Button Bulb Change
- Do you regret lowering your Civic?
- Lowering civic
- Body Trim
- So now that the timing belt/water pump is done.....
- Front Lip Fittings
- Side Molding?
- E brake Doesnt Work
- Progressive camber kit of jcwhitney..???
- Suspension/Springs for Del Sol
- Headlight Problem
- type r cams
- hmotorsonline and total JDM not responding?
- E-brake release button...weird question
- curious...
- dual runner gsr swap
- Need help with color code.
- 96CIVIC SI(usa-EX) PVC valve location,if it has one???
- D16 valve cover
- how much does it cost to get springs installed???
- Clutch help needed
- CV joint boot clamp,do I need special tool to install?
- Dash
- Upgrading front sway bar
- will jvc KDLHX500 fit in my 2002 honda civic?
- stock civic muffler inlet/outlet
- Help fixing manual window 96 Civic hatchback
- 96-01 civic cv boot replace HELP.
- Headlights
- Hood Pin Question
- Rear lip question?
- 99 Civic front Bumper
- Ringing Noise!?!?!
- Stuck doing timing belt and waterpump...
- Can't Reverse
- is my p2p ecu auto or manual
- parts same for hatch, coupe, sedan
- coilover ?
- RV towing a Civic
- Need help with installing a Heaplight in a 2000 Civic EX
- Body Modifying
- HELP: Hard to shift
- LF: 93 Del Sol Wheel Centers
- Post your sol's suspension set up, or dream set up!
- how to adjust timing on D16 SOHC VTEC
- Civic got totalled!
- eg hatch lips
- Removing a spoiler...
- H&R race springs
- ID plate?
- Drum --> Disc Conversion (delsol) Brake line not working!
- Wideband o2 Sensors
- Car Fax For Me!! please
- Anyone with the ek hatch n spoon spoiler
- Brightstar HID H4 hi/lo kit
- What parts to you have sitting around awaiting installation v.437282^8
- UH OH spaghettio...car smokin
- Gear not engaging?
- Crank, but no Start problem?
- Losing Coolant >:|
- changing clocks?
- Door problems
- Comfortable Racing Seats?
- please help
- clicking sound when i accelerate
- whats a good asking price for 99-00 si rims?
- Cheap Ground Control Coilovers???
- ???Air suspension??
- Need help with dashboard ASAP
- Powder Coating my Intake Manifold
- new to forums sayin hi
- Gauge Swap Question DX to EX
- New member with B&W photoshoot of 92 sedan with B18C
- 92 Civic hatch, modded, at silent salvage auction, what should I bid? *pics*
- ????? Which Evap Purge Solenoid for Swap ??????
- Some pictures
- honda oil filter wrench? any comments?
- Are Integra or JDM front disk brakes the same as civic?
- whats bad about Ractive Evotion Lowering springs??
- willl these do the job?
- If you don't want understeer you need this :)
- Emissions problem, need new cat? Where are best prices?
- door latch question
- Moonroof Drains?
- EX alloy weight? 2000 vs. 2004
- :( Its gone!!
- someone help quicK!!!
- Wiring Chart for 95ex door?
- H&R Springs and KYB GR-2 setup????
- anyone know where to get an RS grill?
- do stock springs sag any????
- Looking for one of these.
- Front Turn Signals
- 2-way pager alarm
- HEY ALL!!! Need some help
- Where to get a leather owners manual cover?
- Which civic is the v-tec?
- Side skirt help
- lightweight battery options???!!
- Can you guys tell me the pros and cons of the 2005 Civic Sedan?
- spark plug choice
- how many quarts of oil to use? (reply fast puhlease!!)
- real weird one for you guys
- I need a type r grill for my 99 civic asap..where to order?
- Any way to get my clock to display 24 hour time?
- Anitfreeze mixture question for smart people?
- door handle removal (last thread is fubar)
- door handle removal (97 civic ex power locks)
- Integra OEM rear "diffuser" bumper on a 6th gen civic?
- Del Sol Advice Needed
- oil filter and what type of oil do you use
- Some Advice!!!
- 96-98 c/f lips
- -=Ground Control Coilovers Question=-
- hood
- Whole block or just the inserts????
- Need help finding a pic.
- D2 Coiloverkit
- Idle control valve
- Honda-Tech Members!!!!!Need help!!
- EVO2 Cat Back Exhaust
- Need Help
- where do I go from here
- Buyin A Car!!!
- Massive Confusion!!!
- help: DC TCS Exhaust
- 3 inch exhaust
- P28 ECU problems *urgent*
- So my CEL is on... but I ran into a problem
- RSX Seats
- Catalytic Converter 1G!?!?!
- dip stick problem
- HELP!!! Cant make up my mind :(
- need tp put head on
- what to do and what to get?
- woot! took off ac, what to do with wires?
- Civic brake problem!!
- Catlaytic Q
- Carfax For Me!!!!
- tranny identification
- will a stock usdm d15b7 tranny work with a JDM d15b vtec motor?
- Sohc Engine Rebuild. Anyone have great info?
- Why is it falling on its face?
- Stickers that add horsepower!!!
- d16y7 short block on d16z6 head???
- I'm New. How much would I be looking to spend for a 96-00 Civic?
- Lip
- what are good shocks for ride height????
- E-bay hp
- Carpet??
- LS/GSR Swaybars on EG8
- newbie question for my civic si
- Got some new parts
- which pieces of the interior to paint on a 94 civic dx...what stuff just snaps off?
- International Help
- Eg???
- Parts for b16a motor?
- integra dash swap
- you eg6 fans have to check this out
- Cleaned her up *PICS*(56k...cure cancer)
- Problems after swap....
- does the d16y8 respond well to mods?
- H22 swap/ suspension ?!?!?!?!?!?
- My Sol
- Four door rear view mirrors.
- Grounding Wires Installation - '01 Civic
- When to replace timing belt on 95 Civc LX with 107k mile
- Alignment
- How to program Zex nitrous
- about the kiwami concept
- some pics of my car. what do you think?
- I need power!
- angel eyes projector lights for honda civic 97
- HID HB series help!!!
- Intake Air Temperature (IAT) "Code 10" help
- Alarm Problems
- bolt that holds lug nuts on
- 96 ex 5 spd what tranny fluid to use
