ecu options
Old Feb 17, 2005 | 08:46 AM
barcardi_blasta's Avatar
barcardi_blasta
Default ecu options
here is the idea im swapping a OBD2 (1996 LS)B18b into a OBD1 (1994)Civic CX. Should I A. get a OBD1 ecu and Dizzy or B. get the ecu conversion harness to make the OBD2 ecu work with my setup....
Old Feb 17, 2005 | 08:48 AM
1fasthb's Avatar
1fasthb
I say sell the odb2 dist & ecu and buy obd1 parts. It's so much easier that way.
Old Feb 17, 2005 | 09:48 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You can run all OBD2 engine items, but run an OBD1 ecu.
Old Feb 17, 2005 | 10:08 AM
teg92's Avatar
teg92
WHAT OK YEAH!
:werd: I also would change everything over to OBD1 i think all you need to change is the Dizzy, alternator and i think fuel injectors
Old Feb 17, 2005 | 11:03 AM
westcoaststyle
:doh:
YOU DO NOT NEED TO CHANGE THE ENGINE OVER... once again, you can run all OBD2 engine parts, but just run an OBD1 ECU.
Old Feb 18, 2005 | 12:41 PM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
:doh:
exactly, I have no idea why people think they have to convert over. It works perfectly. I've been running mine (OBD2b engine/distributor/injectors/etc on OBD1) for over two years now with no problems at all.
Now if you don't have the engine's harness that is different. The injector clips, distributor and alternator plugs are different for OBD2a/b to OBD1.
But since the LS injectors are almost exactly the same rate as DX/VX/SI D-series injectors, switch them. Since the alternator is the same output as your CX, switch it. And you can re-pin the LS distributor conector really easily.
Old Feb 18, 2005 | 02:40 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
First off...are you residing in CA. and do you plan to make it legal for emissions and street use? If you are residing in CA. you need to run the OBD2 setup for emission purposes.
Old Feb 18, 2005 | 03:27 PM
Relic1's Avatar
Relic1
Since I'm not in CA and thus don't have to keep track of the laws... I thought Emissions are based on the chassis. Since he has a 1994 CX he should be tested as that.
Or have they become an even larger PITA than I thought? (if that's possible)
Old Feb 18, 2005 | 05:25 PM
asiandoood's Avatar
asiandoood
you have to check with your local laws and local state laws for that. in california, it is the law that the engine must be same year or newer, and has to come out of a passenger car only.
Old Feb 19, 2005 | 04:08 AM
barcardi_blasta
Well I am in Alabama no ****ing testing so that isnt an issue
