Engine reving higher than normal
Old Feb 15, 2005 | 09:45 AM
civicburner's Avatar
civicburner
Default Engine reving higher than normal
My sister's car is revving higher than normal. She told me that when the car is stopped it is revving around 3000rpms. She lets it warm up for over 5 min in the mornings. Could it be the timing belt, thermostat? I'm just not sure.
Old Feb 15, 2005 | 06:06 PM
dx2gsr's Avatar
dx2gsr
when it revs up to 3000 RPM's, is that when the car is fully warmed up or is that cold start?
maybe a plugged filter or stuck throttle cable? :idunno:
Old Feb 16, 2005 | 03:44 AM
civicburner
It's fully warmed up
Old Feb 16, 2005 | 03:56 AM
CivicRacr's Avatar
CivicRacr
i had mine idle high when the engine was warm, found out i knocked a vacuum hose loose when i was working on it, check to see if all the hoses to the manifold are connected and no leaks can be found
Old Feb 16, 2005 | 04:16 AM
civicburner
does anyone think it could be the transmission she drives an automatic? I will check the hoses though.
Old Feb 16, 2005 | 05:13 AM
sibiryk's Avatar
sibiryk
I would check a throttle. Open a hood and force it to closed position manually.
Old Feb 16, 2005 | 07:58 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
If it does it when shes stopped then I doubt it's the tranny, more than likely it's a vacuum leak.
Old Feb 16, 2005 | 08:54 AM
Jafro's Avatar
Jafro
I'm made of meat!
No. Her transmission is engaging hard and operating like crap because it's being shifted at 3000 RPMs. You have a classic example of an intake leak.
