- Integra dash in EG - Pics
- intake question
- help/ ideas.... head problem
- Turn Signals Not working but hazards do.
- squeeky brakes
- Low beams not working
- Can someone help me? Need to change shift boot
- Header Question
- Lightened Flywheel and turbo!? Yes or No?
- allmotor build up with oem honda parts
- new 02 sensors still check engine ?
- about distrubutor rotor
- can I put hood lock on stock hood?
- 97 Civic MES Connector
- Good News!!!
- new engine
- Need Suggestions
- when i start my car it make a sqeaky noise
- OBD1 alternator question
- Rattles
- Need Help Im Just Startin
- interior LED
- Need Help~ SRS light turned on?
- Keyless-less 96 Civic
- windshield wipers and others
- Rear bumper with licence plate molded in it ?
- 4wd civic
- Orthia or Domani front end on Civic Ef6
- 205/55/15 tires OK??
- Civic CVT Transmission Trouble
- How many miles on your 01-05 civic?
- CV Axle replacement then wheel alignment messed up??
- anyone know where I can find
- drilling holes for strut bar
- i've got a pool in my trunk.......
- Safe to run stock b16 retainers to high rpm
- Valve Cover/Engine Bay painting help
- 2000 civic ignition
- fitment
- 2001 Civic, navi install?
- 93 Del sol si RPM Needle Jumps??? Please help!
- Painted alloy wheels
- wash my engine bay need help
- Help with Sticky Steering
- Del sol power control module
- i need a professional opinion
- GSR EK Swap
- Is There A Speed Limiter On My 93 Civic D15
- I've joined the dark side..
- What can I improve on m my vtec???
- 92 Civic Guage Cluster Lights
- noob question
- wiring a tach
- 96 civic jdm climate control
- just got some free seats...sweatness!
- Broken into...Stereo stolen.
- carfax for 4dr civic?
- Headgasket??
- Jun Valve Springs with CTR cams
- Intake Manifold swap
- Heavy duty pres. plate or xtreme?
- moon-roof problems
- climate control bulb sizes?
- Modding Auto EK
- Transmission
- Limited adjustability w/ front camber kit
- Looking for Wheels
- d series question!!
- changing red LED to blue LED of alarm???
- I think Alternator problems
- '95 Civic EX IAT Sensor Voltage High
- 93 civic vx
- is a 96 ex VTEC?
- 98 Acura 1.6 EL - CD Player Unlock Code
- seat harness hook up?
- custom "front lip"
- 07 civic stalls when...
- Battery Light!!! HELP!
- Transmission Noise
- Noob Question, Sorry
- Question on the gauge cluster EG to Integra conversion
- 94 civic throttle body question
- I need help
- civic chips on ebay.worth it?
- My Civic vs. Dumptruck PICS*
- Wiring b18c1 into EG
- Car Stales at Low RPM
- NON urethane bushing replacements
- H22 in 95 civic NO REVERSE HELP!!!
- removing the evaporator core
- turbo question
- Honda Civic 96 Door Trimming!!!
- guage clusters
- swap info b16a into civic91
- 1994 Civic AXEL to transaxel
- These leaks are the worst..
- SRS Light Covered Under Warranty
- 99 civic stalls
- P2P or P72?
- final drive ratio
- EG interior questions
- civic hatch 94 taps
- spitting shit out the exhaust!!
- Good headlights on Ebay?
- I'm signaling way too fast, help!!
- 92 Civic Si stalling???
- anyone know?
- Power locks for hatch question
- looking for a del sol manual trans
- What is the best seat? (OAM/Aftermarket)
- Helium or Slipstreams?
- b18a1 in 1995 civic cx
- S2000 OEM Steering Wheel in a Civic???
- help with starting problem
- Pictures.v2
- sir-ii guage cluster in a cx/dx??
- Auto to manual
- Won't Start...
- Idle/Throttle problem.
- Stolen Car: Edmonton, Alberta location! October 9, 2006!
- suspension problems.
- lights and heater wont work
- what pistons to raise compression in JDM B16A?
- del Sol H22 swap
- Power Steering Flush in 1998 Civic EX
- which engine to swap
- torque spec help
- Can any one Identify this color?
- Changing Head Gasket
- rear disc brakes on a 94 civic lx
- Shaving moulding on a civic
- Interior center console switch Eg-Integra 96
- Help me pick a muffler
- rear seats
- Tire Fitment???
- Air constantly coming through vents
- Side Clips
- 1998 Civic Si ignition problems???please help!
- Some pictures.
- do you guys think my d15 will blow wit a t3 greddy turbo??
- suspension???
- newby to this site
- B16b2??
- i need a manual pedal assembly for del sol
- Car won't start, and died on the freeway... help?
- computer
- Installing Springs on 6th gen civic
- Quick 92 civic radiator Question
- Timing belt wants to jump teeth.
- cold start problem
- 95 civic exhaust
- Help Me With A Decision
- 92 Civic 1.5l No start, new distributor, has spark and fuel HELP!!!
- Some body work help...
- muffler?
- 92civic tbs installation
- CAm guide?
- Installing Fog lights on EG
- manual swap into a 95 del sol si
- do i have to take my car to the shop
- 97 ek hatch no power steering??
- Muffler I.D.
- i need some new light bulbs
- overheating when i boost
- What gets the HX the good gas mileage?
- diagnostics Code troubleshooting
- how do i get pics on a thread??
- wiring diagram for a 95 civic...
- I Have A Noisy Sound Under My Car!?!?!?
- Tein Coilover adustment
- Went to the track
- Finally got my SiR!!
- Bleeding Air from radiator/overheating
- Which cams, CTR or Crower Stg 2
- carpet questions?
- Integra Type R header opinions
- " 95 Civic ex BoostiN "
- Ls turbo [eBay SOHC Turbo Kit query... draw your own conclusions, folks.]
- trying to learn about motors
- what do yall think
- No Cluster Lights :(
- which rims
- Need some help ASAP with finding...
- Water leaks
- vss???
- Did anybody see that video??
- Delsol with GSR motor and auto tranny?
- stech or h&r race pics?
- mugen side skirts
- Good Bye Baby :(
- a good place to get new rotors?
- 94 civic Tranny filter and gasket?
- buying my first car and wanted to know something
- h22a vs b18 vs b16
- New pics finally rollin!!!
- What to pay for EM1 Civic Si? [Split & Moved]
- lifters?
- My first 12 sec. pass (vid inside!)
- need a good civic, and powertrain build list
- Compression
- fuel issues ?
- Spark Plug wires: When to change them...
- Switch to the fat fives?
- crx/delsol tranny questions?
- hey motor problems
- grounding kit ????
- DOHC ZC questions
- Protecting paint on new civic
- lol oh yeah
- del Sol Distibutor
- Will 00 SI fenders fit all other civics????
- suspension for 07 civic ex
- Getting tint tommorrow...IDEAS!
- New member
- how to remove head light lense
- intake manifold torque??
- custom seats
- msd ignition
- Power window regulator/motor
- Something was bound to f*** up....
- question someone help please
- wanting to leave coilovers
- Help, my Civic is reving itself!
- swaping trannys
- question| Increased Flow, Horsepower And Torque
- New pics of my hatch version II.
- del sol swap
- What kind of steering wheel are you running?
- Pics
- h22 swap need help with
- Need help on finding frontend
- Hey Everyone
- Know where I can get a cheap D16 vtech?
- Replacing stock suspension HELP
- Swap Time! b18a into 96 CX Hatch
- Oil cooler?
- 1991 Civic With B18 Swap Issues...
- Engine break in....
- picked up a k20 w/ tranny for MAD cheap
- Anybody ever bought a cheap ebay turbo?
- si ecu in an ex?
- Turbo?
- skunk2 cam gear doesnt have the notch to lock it with the came
- out driving my suspesion
- DC2 Recaro seats....Need help to choose
- Should i do it?
- My Shit sounds like a subaru?? WTF
- Cam Seal Question
- SRS Light is on
- Air Intake Temp. Sensor and P2T ECU?
