can someone help me?
Old Dec 8, 2006 | 07:45 PM
AEMsi's Avatar
AEMsi
im still thinkin...
Default can someone help me?
ok i know everyone knows this here, except me...
whats the difference between K20A3, A2, or A?
im confused.
Old Dec 8, 2006 | 08:27 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
ask and you shall recieve
K20a-JDM ITR and CTR both come in with 11.5:1 compression and 2 liters of displacement. The Type R motor is rated at 220hp at 8,000rpm and 152lb-ft at 7,000 rpm. The CTR is rated at 200hp and 144lb-ft. Both of these motors have the same VTEC mechanism as the older B series motors but with the addition of VTC. It also has Larger cams, higher compression and larger intake manifold than the Type S motor. This motor comes with a 6 speed transmission and LSD. The 6-speed manual transmission uses multiple synchronizing cones for all gears, including a triple-cone synchronizer in 1st and 2nd gears and a double-cone synchronizer in 3rd through 6th gears.
K20a2-Acura Rsx Type S has 11.0:1 compression and 2 liters of displacement. The Type S is rated at 200hp at 7,400 and 142 lb-ft at 6,000 rpm. This motor also comes with a 6 speed transmission with no LSD. It has the same VTEC mechanism as the older B series motors but with the addition of VTC.
K20a3-Acura Rsx Base and Civic SI models come in with 9.8:1 compression and 2 liters of displacement. The Base motor is rated at 160hp at 6500rpm and 141lb-ft at 4000 rpm. This motor does not use the conventional VTEC mechanism from the earlier B series motors but does have VTC. Instead it only has 2 cam lobes on the intake side and 1 on the exhaust lob. This motor has no VTEC mechanism on the exhaust cam and runs on 12 valves before 2200rpm. It also has smaller ports than the Type S and Type R. The motor also comes with a 5 speed transmission instead of the 6 speed and has no LSD.
Old Dec 8, 2006 | 08:36 PM
Driverman5777's Avatar
Driverman5777
the new civic SI has the same engine as the RSX type S
Old Dec 8, 2006 | 08:45 PM
AEMsi's Avatar
AEMsi
im still thinkin...
ok thanks man.
ur talking about the 06 si right?
im glad i got that figured out lol
thx
Old Dec 8, 2006 | 08:48 PM
Driverman5777
yes
Old Dec 9, 2006 | 09:22 AM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
the 06+ si has a k20z1 not a k20a2(k20a2 02-05 rsx-s)
Old Dec 9, 2006 | 01:41 PM
Snoopy's Avatar
Snoopy
been there done that
www.k20a.org
everything you wanted to know about the k series and then some.
Old Dec 9, 2006 | 02:19 PM
Driverman5777
damn this time I was owned...
O well at least I remembered it had a K20 and it had the same specs
Old Dec 10, 2006 | 01:29 PM
Mugenfreak's Avatar
Mugenfreak
Boost Hungry!
its all good....actually the k20z1 is would be about 210hp by the old SAE hp ratings(they changed last year i believe) but they changed them to be more accurate or realistic so thus the 197hp rating
