Exhaust-muffler weld rusted
Old 12-02-2006, 07:10 PM
meitzner
meitzner's Avatar
Default Exhaust-muffler weld rusted
1997 Civic LX w/102k miles. While the exhaust pipe and muffler both look to be in great condition (e.g., no rust), the weld that holds them together has apprarently rusted through or broken off somehow and the car is loud as hell. I want to fix this the cheapest way possible. Any suggestions? I was thinking of maybe using a reducing adapter and putting the small end in the muffler, and the large end around the outside of the exhaust pipe - then sealing it all up with muffler cement. This would reduce the diameter of the muffler pipe by about 1/16" all around which doesnt' seem too bad, eh? I could also buy an aftermarket muffler off ebay for like $20. I'm sure it's not great quality, but then I could just splice it to the old exhaust pipe and voila - problem solved. I know I won't get much gain out of this solution, but it should quiet the noise at least a little, right? Any other suggestions or comments on which of my thoughts might work best?
Thanks
Old 12-02-2006, 07:13 PM
Snoopy
been there done that
Snoopy's Avatar
go to a junkyard and find another oem muffler
Old 12-02-2006, 07:18 PM
Nissan420
Thanks for Caring
Nissan420's Avatar
I got one i'll give you if you can pick it up lol.
Old 12-02-2006, 11:29 PM
tommyhcky13
tommyhcky13's Avatar
lots of jb weld
Old 12-03-2006, 05:24 AM
meitzner
meitzner's Avatar
THink JB Weld would work, seriously? I also saw another product - Muffler Cement, which said it holds up to 750 degrees, whereas the JB Weld works only to 500. How how do you think the muffler gets? Also, would it be better to splice a pipe into the muffler and then around the exhaust pipe and "JB weld" it all together, or just try to JB Weld the existing pipe to the existing muffler/hole?
THanks,
m
Old 12-03-2006, 05:57 AM
tommyhcky13
maybe the exhaust cement will work better because it's like fiberglass and has some kind of mesh to fix a hole. good luck
Old 12-03-2006, 07:38 AM
fathergoat
:3
fathergoat's Avatar
:werd: if you can find one that isn't completely rusted it'll probably be just as cheap as the exhaust repair crap, and will last longer. if you can't get to a junk yard find out how much a replacement would cost at autozone. you might be surprised.
Old 12-03-2006, 09:23 AM
Mugenfreak
Boost Hungry!
Mugenfreak's Avatar
or go to a muffler shop and get them to reweld it and spend the extra cash and have them use stainless steel rods so it wont rust in the future :werd:
Old 12-05-2006, 06:38 PM
delsolcharlie
delsolcharlie's Avatar
yea my 93 del sol rusted out right behind the muffler..i guess it is a falty weld...i thought i was the only one with that problem
Old 12-06-2006, 07:17 AM
Running925
Your Powder Coater
Running925's Avatar
or you just just buy a short sleeve of slightly larger diameter than the current piping, slide it over both ends & clamp it down FTW..
or find someone to weld that shit back up!
