Oil leak on valve cover!! Help!
Old Dec 13, 2006 | 01:35 PM
Ziken's Avatar
Ziken
RACE USE ONLY
Default Oil leak on valve cover!! Help!
I noticed that i have to keep filling my oil up, and I think i know where its leaking from. There's this bolt on the top of my valve cover that is always drenched with oil every time i refill the oil. see red arrow....
how do fix it!? I tried to tighten up that bolt but it seems as tight as i can get!!!
Old Dec 13, 2006 | 02:55 PM
m735is's Avatar
m735is
There should be a rubber seal under there that gets hard with age. You may try wiping off the valve cover just to make sure it's coming from there.
Old Dec 13, 2006 | 05:23 PM
teg92's Avatar
teg92
WHAT OK YEAH!
you probally need a new gromett, i would just go to Honda and get a valve cover gasket kit.
Old Dec 13, 2006 | 06:30 PM
Outxider's Avatar
Outxider
X-Motoring
^agreed. just get a new valve cover gasket complete with grommets and that engine bay needs a steam cleaning session.
Old Dec 13, 2006 | 08:10 PM
simplyredvw's Avatar
simplyredvw
While your picking up the gasket set from the dealer, pick up some HondaBrite. Your engine will thank you for it later.
Old Dec 14, 2006 | 05:32 AM
Running925's Avatar
Running925
Your Powder Coater
definatly needs a valve cover gasket kit! As well as about 8hrs of cleaning!
Old Dec 14, 2006 | 07:06 AM
theoszarz14's Avatar
theoszarz14
93SolSI
I have the sma kind of problem, except mine leaks because the 2 of the bolts that tighten down the valvs cover it self wont tighten all the way. The first time i took it apart and put it back to gether when i was putting 2 of the front bolts on its seemed as if they were stripped. Any suggestions?
Old Dec 14, 2006 | 07:47 AM
Running925's Avatar
Running925
Your Powder Coater
put new studs in
Old Dec 14, 2006 | 09:23 AM
theoszarz14
93SolSI
Do you know where i can get the studs from or am i going to have to go to the stealership
Old Dec 14, 2006 | 07:14 PM
simplyredvw
They don't cost that much at the dealership.
