mad....ugh
Old Nov 15, 2006 | 05:19 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
Default mad....ugh
I recently bought a 92si and....nothin freakin works...the gauge cluster won't work (the lights do)....there is a water temp gauge and a fuel gauge on the A-pillar which don't even have wires.....the blinkers don't work and there is some more stuff but that doesn't matter....alright question is
how do I get those gauges on the A-pillar workin? (how do I wire them etc)..they are stewart warner gauges if that helps
what do you think needs to be done about the gauge cluster?..what should I check for?
thanks in advance and I am sure I will have more questions soon...h:
Old Nov 15, 2006 | 05:26 PM
Misa's Avatar
Misa
Pic Whore
did you even look at the car before buying it?
Old Nov 15, 2006 | 05:38 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
yes I did...I guess just not that well.....I knew the gauge cluster didn't work.....the others well I didn't know
Old Nov 15, 2006 | 05:58 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
ok nevermind...I am taking the A-pillar off.....the question is
where should I start with the gauge cluster?...would buying a new one be the best idea?
Old Nov 15, 2006 | 06:53 PM
Omniscient's Avatar
Omniscient
warm butter on toast
If you can get your hands on one without buying it, swap it out and see if it works.
Old Nov 16, 2006 | 12:30 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
well I got a power tester light....and apparently there isn't any power getting through there....BUT..the weird thing is...if I plug in everything and turn my lights on etc...they light up....idk I am so confused and I need some help
Old Nov 16, 2006 | 01:37 PM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
check your speed sensor. My cluster didn't work, I made big fuck up...when I did my swap, the plug that goes onto the evap canister is EXACTLY like the one that goes onto the top of the tranny for the speed sensor. Well except the wire colors of course but my wires had grease all over them and didn't bother to clean them off...hope this helps.
Maybe check continuity between the wires maybe broken wire
Old Nov 16, 2006 | 03:54 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
well the speed sensor woudn't keep ALL my gauges from working would it?......this is a fucking joke I think I made a big mistake.....and now when I turn the key to the on position I hear some type of noise like a high powered drill...
Old Nov 16, 2006 | 05:38 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
anyone have any idea what that noise could be?...I cranked the car and its still on....I need some help
Old Nov 17, 2006 | 12:45 AM
A-series's Avatar
A-series
v-card member alpha
Stupid Q: could the cluster prob. be b/c of a bad fuse?
As for that noise, if you hear it with the power on but engine off as well as with the engine running it could be the ABS pump building pressure... hard to say without hearing the noise.
